Any mechanics out their?- Mtbr.com
Results 1 to 8 of 8
    Reputation: pleepleus's Avatar
    I have a 94 Nissan Hardbody Pick Up. I only drive it like 2 or 3 times a week. Lately the clutch peddle has been all the way to the floor when I haven't driven it in a few days. I have to reach down and pull it up with my hand. I pump it a couple of times and its good to go. It shifts fine and normal once I get the peddle back up. The hydro fluid reservoir is full.
    Is this something I should worry about? Is my clutch going out?
    Jan 2005
    I'd lean towards a master cylinder or slave cylinder with internal bypass problem. I would recommend getting it looked into as it may fail completely at a very bad time.
    If I remember the slave is external so no transmission R&R.
    Reputation: FZJ80's Avatar
    Had it been serviced recently?
    As mentioned above the clutch is probably fine, it sounds like you have a seal problem. I never understood the fascination with hydro clutches, a linkage is more direct and you get more feel. You have no idea what a nightmare it is to bleed a clutch on a Saab 9000 or a FJ40 Landcruiser.
    2012 Trek Marlin
    Reputation: kuritaro9's Avatar
    +1 on the slave/master cyl.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Quote Originally Posted by kuritaro9 View Post
    Me too.
    I like turtles
    Thanks guys. I'll get it looked at when I can. I have another car I just put $600 in, so the hardbody will have to wait. If it gos out on me I know how to drive it with out the clutch.
    tl1
    tl1 is offline
    Bicyclist
    Reputation: tl1's Avatar
    Out their minds?
    Or "Out there"?
    They're/their/there
    About $30 in rebuild kits , $5 in fluid and do it yourself. Simple and easy, will take roughly 2 hours, 3 if you have no clue.
  1. -1 for LBS Mechanics
    By Munin2889 in forum Tooltime
    Last Post: 02-25-2009, 01:13 PM
  2. Experienced RP3 mechanics
    By 92SE-R in forum Shocks and Suspension
    Last Post: 11-27-2007, 08:29 PM
  3. Best Mechanics
    By Matai in forum Washington
    Last Post: 12-20-2006, 02:16 PM
  4. Mechanics
    By zerossix in forum Downhill - Freeride
    Last Post: 01-16-2006, 02:54 PM
  5. Attn Mechanics, Need Help!!!
    By sworkspilot in forum General Discussion
    Last Post: 12-17-2005, 06:56 AM
