5 bikes!! Need bike rack!!- Mtbr.com
Results 1 to 19 of 19
    Reputation: crclawn's Avatar
    Car 2001 Lexus GS430.
    Bikes:
    (2) 29er Specialized FSR stumpy
    1 Cannondale 2010 29er HT
    1 Giant 2011 XtC 2 29er HT
    1 Fuji 29er Comp HT
    I ride with my girlfriend about 60 % of the time, so just normally take 2 bikes. There are occasions when I want to take 3 or 4 bikes.
    Will order this:
    http://www.etrailer.com/hitch-2001_L...&furl=-pm-Curt
    I want this. Problem: Above reciever is 1 1/4 inch. (The only thing for my car). Tounge weight is 250#. Can I get this rack and and just use a 2" adaptor? I want to be safe.
    http://www.amazon.com/Hollywood-Rack...2702395&sr=8-4
    If i cannot get above rack then which one should I go with. The one will carry 4 bikes and the other style will carry just two bikes:
    http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
    I am open to all suggestions but would like to keep the bike rack under $300. Thanks for the suggestions or info.
    putting that many bikes off the back of that car is going to be hard on it. If you have the dough I would use a roof rack and hitch rack combo. put two on top as your primary use and two on back for when you want more bike storage. thats what I would do.
    or you can just get a reducer for that rack, make sure to get an anti sway shim for the hitch so that you can minimize the forces applied to the hitch.
    mtbr member extraordinair
    Reputation: Stupendous Man's Avatar
    Thats a tough price limit. I think for 5 bikes you will probably need to combine a hitch rack and roof rack. Or, get the hitch and a small trailer to load the bikes on.
    Grit, spit, and a whole lot of duct tape!
    I'm starting to lean with a 2 bike platform rack and the 2 bike on the roof rack. I'm just limited by the 1 & 1/4 reciever hitch. Its the only thing that I can find for my car and its only class 1. I think I'll just get the reciever hitch and the two bike rack for now and add the roof rack later. Thanks for helping out.
    DynoDon
    Reputation: manabiker's Avatar
    I'm the only one I've seen pulling a trailer, Stupendous man is the first one I've seen mention one, but its a great way to carry your bikes, easy to load, unload, no damage to car, great fuel mileage, inexpensive too.
    I bought this trailer from Harbor Freight, list $179. I found a $20 coupon online, then I removed one leaf from each spring, since I wouldn't be hauling much weight, I moved the center crossmember up 10 inches, that made the tounge longer so the trailer doesn't sway, I put 2x10 wood on for a deck, adding weight to help the trailer stay on the road, it pulls great behind my motorcycle, I've made it up for 2 bikes or one in the center, you could easy mount 5 bikes, 3 forward, 2 towards the back..check it out
    <a href="https://photobucket.com" target="_blank"><img src="https://i892.photobucket.com/albums/ac122/manabiker/P2180005.jpg" border="0" alt="Photobucket"></a>
    <a href="https://photobucket.com" target="_blank"><img src="https://i892.photobucket.com/albums/ac122/manabiker/P2130001.jpg" border="0" alt="Photobucket"></a>
    <a href="https://photobucket.com" target="_blank"><img src="https://i892.photobucket.com/albums/ac122/manabiker/P2180004.jpg" border="0" alt="Photobucket"></a>
    Nice set up bro. Have u thought about painting it black to.match the bike?. I had one of those and did some serious mods. Back then I had a crap load of wielding eqip. I added three feet to the main bar that connects to the tongue and added two feet to the trailer plus sides and a gate. I wish I would have never sold that thing. Should have taken pics.
    Under $300 is tough with racks. If I understand, you own 5 bikes, but only want to carry 3-4 at a time?
    If so I would recommend a roof rack with a wide enough bar for 4-5 bikes. One of the nice things, is you could start with 2 bikes, then add as you have money. Having said that $300 won't get you far. You might want to start scouring Craigslist and the like.
    I wouldn't put too much weight on the hitch. 4 bikes sounds like a lot for a 1 1/4 hitch. The adapter will only allow you to use a 2" receiver, but will in no way make the hitch stronger. Not to mention it will adversely affect the car.
    Having 2 on the back and 2 on top is nice, but tough within $300.
    Hope this helps. Good luck.
    DWDW, helps alot. Have made up my mind to get the two bike rack (platform) on the back and then add the roof racks later. I think I like the versitilay of the roof rack. thanks
    That trailer kicks ass! Now I need to install a hitch on my motorcycle!!
    I know this is a bit of a digression, but there are almost infinite possibilities with a trailer.
    This is the trailer we pulled to Moab from Iowa last year. It held 12 bikes and all our gear.
    Nice!!!
    Jan 2005
    This is worth the extra ducketts.
    http://www.northshoreracks.com/
    The OP already stated that he could only mount a 1 1/4 inch receiver on his vehicle. The NSR-6 is only for a 2" receiver.
    I do agree that they are nice racks, and I had given serious thought to buying one for myself before I bought my Thule.
    I want to get the Softride Dura. The only problem is that it says its for class 2 recievers (it will fit a 1 and 1/4 reciever and the one I have is 1 and 1/4 but class 1). I can only get a class one for my Lexus, which can hold 250 tonge wieght. I'll never exceed this. Can I still use the Softride Dura with the class one and 1 1/4 inch reciever, even though the Softride dura says that its only for class 2. Any help appreciatied. I am getting ready to pull the trigger on this.
    Here's the bike rack:
    http://www.autoanything.com/bike-rac...x?kc=ffproduct
    Looks like it should work, if it'll fit a 1 1/4 inch receiver. Like you said, just don't load it too heavy and you'll be OK.
    Thats what I was thinking too. I would only cary 3 bikes at about 28 - 30 pounds each. Plus the wieght of the rack so I would only have about 125 to 135 pounds on it. The tonge weight is 250. Anyone think this is a bad idea?
    Reputation: norcal2's Avatar
    Quote Originally Posted by crclawn
    I bought an 1 1/4 to 2 inch hitch adapter,(they are common) went to a local welding shop and they cut out the 1 1/4 and welded in the 2 inch piece...no problems....
    Mar 2011
    as long as you don't exceed the weight limit of the hitch you should be fine. not sure how much force is applied with 100+ lb bouncing around on the road though.
    The main difference I noticed between class 1 vs class 2 is the doubled up thickness on the receiver.
    Quote Originally Posted by irv_usc
    The rating is for static loads only, not dynamic loading, so no need to consider it bouncing. There's plenty of design margin in that rating too.
