20mm and 15mm options for roof rack- Mtbr.com
Results 1 to 7 of 7
    Reputation: Dr Saw's Avatar
    Jan 2005
    Just got a Ford Fusion. Need a rack (preferably) with universal key system AND a locking, front wheel off, rail.
    What are my options. Thx!
    What Hill?
    Upright or adapter are your choices. If you're looking at Yakima, something like a High roller or King Cobra upright (wheel stays on), or an adapter that you put on a regular fork mount and work out your own security for. Most just use a cable.
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    Quote Originally Posted by eric1115
    what he said, except for the king cobra. it's discontinued and there are way stronger racks out there nowadays.
    any fork mount is going to require you use a 20mm or 15mm qr adapter like this. it will lock in to the bike rack, but you'll have to lock your bike somehow to the rack and a cable lock will do this.
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Rockymounts
    You could use a rockymounts flytrap. It will take 20mm stock.
    I just got two of these and put them on a custom roof basket.
    My XC bike has a 15mm fork and mavic crossmax wheels.... I had Risse Racing make some adapters to step the crossmax hub down to 15mm, and they should work fine with the flyrtap.
    I just got all this put together and haven't hauled my XC bike yet... so no guarantees. I can report back with pics in a few days.
    By the way.... Word is that Rockymounts will have a 9/15/20mm product similar to the flytrap this year.
    code: mtbr2011
    Quote Originally Posted by FM
    i believe this was unveiled at interbike. we are expecting to hear more from rocky mounts about this.
    FM
    FM is offline
    Apr 2003
    Flytraps work great
    Did a little roadtrip over the weekend, in 3 days I had every possible front axle size mounted up to the rockymounts flytraps. They work great- lockable, very solid connection and easy to use.
    For 15mm, you do need 20-to-15mm adapters- I have a pair of crossmax hub adapters from Risse racing which work great and were pretty inexpensive. The adapters go on the axle/bike before mounting up to the rack... easy.
    May 2010
    Rocky Mounts now has a similar through axle that supports 15mm or 20mm sizes called the DriveShaft:
    http://www.rockymounts.com/DriveShaft_p/1081.htm
