• 09-29-2010
    Dr Saw
    20mm and 15mm options for roof rack
    Just got a Ford Fusion. Need a rack (preferably) with universal key system AND a locking, front wheel off, rail.
    What are my options. Thx!
  • 09-29-2010
    eric1115
    Upright or adapter are your choices. If you're looking at Yakima, something like a High roller or King Cobra upright (wheel stays on), or an adapter that you put on a regular fork mount and work out your own security for. Most just use a cable.
  • 09-29-2010
    cracksandracks.com
    what he said, except for the king cobra. it's discontinued and there are way stronger racks out there nowadays.
    any fork mount is going to require you use a 20mm or 15mm qr adapter like this. it will lock in to the bike rack, but you'll have to lock your bike somehow to the rack and a cable lock will do this.
  • 09-29-2010
    FM
    Rockymounts
    You could use a rockymounts flytrap. It will take 20mm stock.
    I just got two of these and put them on a custom roof basket.
    My XC bike has a 15mm fork and mavic crossmax wheels.... I had Risse Racing make some adapters to step the crossmax hub down to 15mm, and they should work fine with the flyrtap.
    I just got all this put together and haven't hauled my XC bike yet... so no guarantees. I can report back with pics in a few days.
    By the way.... Word is that Rockymounts will have a 9/15/20mm product similar to the flytrap this year.
  • 09-29-2010
    cracksandracks.com
    i believe this was unveiled at interbike. we are expecting to hear more from rocky mounts about this.
  • 10-04-2010
    FM
    Flytraps work great
    Did a little roadtrip over the weekend, in 3 days I had every possible front axle size mounted up to the rockymounts flytraps. They work great- lockable, very solid connection and easy to use.
    For 15mm, you do need 20-to-15mm adapters- I have a pair of crossmax hub adapters from Risse racing which work great and were pretty inexpensive. The adapters go on the axle/bike before mounting up to the rack... easy.
  • 07-06-2011
    chillin21
    Rocky Mounts now has a similar through axle that supports 15mm or 20mm sizes called the DriveShaft:
    http://www.rockymounts.com/DriveShaft_p/1081.htm
