2 inch to 1 1/4 inch hitch adapter- Mtbr.com
Results 1 to 5 of 5
    Reputation: NC-Biker's Avatar
    Dec 2010
    The bike rack has a plastic sleeve to adapt it to fit the 2" receiver,not sure how that's going to work out.It also has the screw type pin. What do you guys use/recommend?
    2011 Rockhopper Comp 29er
    2011 Myka HT Disc (wife)
    Use the plastic sleeve and screw pin. And adapter adds length.
    Dec 2010
    Quote Originally Posted by the-one1 View Post
    Let me re-phrase that,can you get sleeves that would accomplish the same thing?
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    Quote Originally Posted by NC-Biker View Post
    a sleeve is usually proprietary to the rack.
    Yakima 4 bike rack with solid arms and rubber pads w/ straps to hold the top tube?
    1 1/4 metal receiver tube w/ a bolt welded in the center of it?
    I have the same one and the 2" adapter sucks.
    This is much better:
    2 Inch Hitch Reducer - ADPT-637
    I bought a better bolt at the hardware store with lock washer and a nut on the other to.
  1. putting a 2 inch rack on a 1 1/4 hitch...
    By pavement sucks in forum Cars and Bike Racks
    Last Post: 08-12-2007, 04:23 PM
  2. 2 inch receiver hitch extension for Swagman XC 2??
    By CJones in forum Cars and Bike Racks
    Last Post: 07-12-2007, 03:58 PM
  3. Using a 9 inch Progressive spring on a 8.75 inch Roco damper...
    By Magick Mountain in forum Shocks and Suspension
    Last Post: 05-22-2007, 05:06 PM
  4. 5 inch front 4 inch rear suspension balancing?
    By briwear in forum Shocks and Suspension
    Last Post: 02-24-2006, 05:28 PM
