15mm through axle rack- Mtbr.com
Results 1 to 14 of 14
    Does anyone know of a through axle mount like the one pictured? I can only find ones that are adapters that mount to quick release mounts. Any help would be appreciated.
    Reputation: tartosuc's Avatar
    Quote Originally Posted by azlakerfan12 View Post
    yakima has an adapter that will adapt the mount you show to 15mm.
    Yea I am trying to avoid using an adapter. I just want something I can bolt directly to a piece of wood or metal. I am making my own rack so that is what I'm trying to do.
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    Hurricane is about ready to release a 15mm fork mount like you have mentioned.
    Quote Originally Posted by Hurricane Jeff View Post
    Do you have any info or link for it? I looked at their site and tried googling it but found nothing.
    Thanks,
    When I say about ready, maybe Im getting a little ahead of myself. Late next month we should have them. What is cool about ours is, once you have your fork in place, you will not be able to access the bolts and models will be compatible with the sliding rack systems that are availible with most late model pickup trucks.
    Old school BMXer
    Reputation: Blaster1200's Avatar
    Quote Originally Posted by cracksandracks.com View Post
    This looks to be way better and a better value than anything that Hurricane would likely offer.
    May the air be filled with tires!
    Hurricane Jeff,
    What's the cost going to be and do you have any pics of it yet?
    Any word on the hurricane rack?
    I hopefully will have some info on this product shortly, sorry for the delay.
    Blaster 1200, whats your problem with Hurricane?
    I have the bikebud15 go check it out https://www.facebook.com/BikeBud15 or www.jdbltd.com/products
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Kuat Dirtbag
    <img src=https://www.bikesonline.com/product_images/t/863/AR1719__86213_zoom.jpg>
    SHJ
    SHJ is offline
    Aug 2013
    I also have the Bikebud 15. So far the best mount I found out there!
  1. 9mm QR vs. 15mm thru-axle
    By awai04 in forum Shocks and Suspension
    Last Post: 02-27-2013, 02:29 PM
  2. 15mm Through-Axle Vs. 9mm QR
    By Joe_Jitsu in forum 29er Bikes
    Last Post: 09-14-2011, 09:31 AM
  3. fox 15mm thru axle
    By swmarc in forum Beginner's Corner
    Last Post: 10-18-2010, 03:30 PM
  4. Fox 15mm axle with 650?
    By jayoutside in forum 27.5
    Last Post: 11-27-2009, 11:23 AM
  5. 15mm thru axle
    By Flystagg in forum Weight Weenies
    Last Post: 10-09-2008, 01:24 PM
