1.25" threaded hitch pin- Mtbr.com
Results 1 to 6 of 6
    Hey all,
    I recently picked up at 1 1/4" T2 and love it. The only thing that troubles me is the hitch bolt. There is nothing to prevent it from wiggling out over time. Yes, I could just buy a locking pin and slide it in, but I like that it is threaded and doesn't wobble.
    So my question is, is there some sort of pin for a 1.25" hitch, that threads in, but can also be locked preferably, or at the very least, it protrudes out the other end so you can put a clip on it or something.
    THanks
    Matt
    Tree Hugger
    I've only had my Thule for 5 months, but it's been on my car the entire time, and while I periodically check the hitch bolt due to concerns like yours, it has remained tight so far.
    Reputation: paranoid56's Avatar
    what keeps every other bolt on your car? this is just another bolt on a car. make sure its tight and you are good to go.
    A nylock bolt, available at any hardware store, will give you the peace of mind you're looking for.
    Az
    Quote Originally Posted by paranoid56
    Very true, just one of those things that would it happen, well, I think everyone knows how I would feel.
    Reputation: mtn_goat's Avatar
    Get a longer bolt, same grade to keep the strength, then drill a hole and put a cotter pin in, or get a locking threaded pin from Thule or any hitch store, or just use a lockwasher and keep it tight, check periodically if you leave it on for a while.
