08 Outback + Highroller?- Mtbr.com
Results 1 to 2 of 2
    I am about to get a rack for an 08 outback and everything I have read here has me leaning towards the Yakima Highroller. It looks like with the mightymount adapter it should go on pretty easily.
    Thoughts on the Highroller and is anyone using this set up currently?
    THANKS!
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    this is a good rack. i would recommend you move your front crossbar all the way forward on the vehicle. this means mounting it so that it sits inside that front little pocket that is on the elevated siderail that goes front to back.
    once you do that, i recommend lifting your tailgate, and measuring from the center of the front crossbar, across a level plane, to the point where it intersects or would hit the lifted rear tailgate.
    let's make sure you have enough room up there for the length of the highroller.
