Big Dummy Build Questions- Mtbr.com
    May 2005
    I'm planning on buying a Big Dummy frame and building it up. As I start to compile parts I had a few questions on compatibility.
    In an older post I saw a reference to Shimano Shadow derailleurs not working. Is that still the case? Was planning on buying a Deore or SLX groupset.
    Also, any idea if stock Shimano hydraulic brakes have a long enough rear brake line? I've had to shorten them substantially for my mountain bikes, but not sure if they're long enough for the Big Dummy.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I know you can buy a Shimano brake hose in 1700mm, which is about 5 and a half feet. Not sure if that works on a Dummy or not. Never tried to buy Shimano hose in bulk.
    I like turtles
    You could check in the Tandem forum regarding the rear brake line.
    Mar 2016
    Stock shimano rear hydraulic breaks 1700mm fit on Dummy.
    I have LX Group set and it work Great.
  1. 2015 Big Dummy Build Qs
    By canyonrider in forum Cargo Bikes
    Last Post: 08-25-2016, 12:13 PM
  2. Big Dummy + Xtracycle Sidecar questions?
    By system-f in forum Cargo Bikes
    Last Post: 02-20-2014, 06:27 PM
  3. Big Dummy questions
    By akclimber49 in forum Surly
    Last Post: 12-09-2012, 01:38 PM
  4. Careby's Big Dummy Build
    By Careby in forum Surly
    Last Post: 04-17-2012, 02:26 PM
  5. My 2011 Big Dummy Build
    By RecceDG in forum Cargo Bikes
    Last Post: 01-12-2012, 08:20 PM
