Results 1 to 7 of 7
    XT M770 Cranks on a Prophet - E Type der spacer??
    The instructions show one 2.5 mm spacer on each side (for e-type der installation on 68mm bb). No problem there. Additionally, they show a 2.5 mm spacer to be installed between the e-type bracket and the frame. That all makes good sense, but I don't see the small spacer w/ my new crankset. Was this supposed to be included w/ the crankset? Maybe I am missing something in reading the installation instructions?
    PDF instructions here - http://bike.shimano.com/media/techdo...9830616011.pdf
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    My Prophet has only 2 spacers. One on each side and it works fine.....
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    One 2.5mm spacer brake side, one 2.5mm drive side with the e-type mount outside, between the spacer and the BB bearing cup. Don't forget the small 2.5mm spacer where the deraileur bolts to the frame above the BB.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Quote Originally Posted by Dan Gerous
    That's kind of the issue in that no smaller spacer came w/ my XT crankset. There IS a spacer/washer in between the deraileur and frame already which looks to be 2.5mm - that spacer came w/ the stock bike (prophet 5 w/ deore LX e-type FD). So my question then, would be...do I need another 2.5mm spacer on top of the stock OE spacer/washer?
    LA CHÈVRE
    No, just use the OE small spacer. The logic is that the small spacer should be the same thickness as the BB spacer you use between the e-type derailleur mounting plate and the frame's BB shell, this will make the derailleur sit straight.
    Appreciate the info DG!
    yeah, i would've posted this last night after i mounted my xt, but my computer is dead at the moment. Just use the one that came stock, i did, and it worked like a charm. no i just have to swap the chain and try the damn thing (though my brand new oro rear brake needs to be bleed that's no good imo)
