Results 1 to 6 of 6
    Where can I get this part?
    Been to a number of different LBS's and I can't track down a front hub for my 2008 Rush w/ Lefty Headshock. I need the six bolt pattern, as the Jekyll that I rode before only has the four bolt pattern. and isn't compatible with my new frame.
    Can anyone tell me where to find a new/used Lefty six bolt front hub online or in the San Diego area?
    Any replies would help immensely.
    Reputation: rumshcawheely's Avatar
    Either 4 or 6 will work with your frame/lefty but it's your new rotor that won't fit your old hub. So just use your old wheel to get you around while you look for a new wheel. Usually there are some on ebay.
    Feb 2007
    If you are wanting to build your own wheel is this the hub you are looking for http://www.chainreactioncycles.com/M...x?ModelID=7265 I think any Cannondale dealer can order it for you.
    A Lefty hub is probably not a stock item at most Cannnondale dealers. I don't know the current situation but earlier this year they were on backorder.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    many on line shops sells the hub
    on ebay usa too
    Found the part! Thanks guys.
