Results 1 to 7 of 7
    What is the weight on the stock Scalpels?
    I was wondering what the weight is on a stock scalpel--obviously, the higher ends will be lighter--what about a 2000? 3000? (2006 models).
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    I'm not sure and it depends what size you get too but if I remember right, the 2000 was around 24.5 pounds, the 3000 23.5 pounds and the team close to 23 pounds.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Aug 2005
    anyone know the weight of a stock scalpel 3 in size large, or a scalpel 1000 from last year? Thanks
    my 06 scalpel size medium with XTR crossmax wheels and stuff totally factory spec i think comes in at mid 24 pound
    Stock Scalpel 3000
    A stock large Scalpel 3000 weighs in a hair under 27 lbs. The frame itself weighs between 5.5 and 6.0 lbs. I have yet to see or weigh a large scalpel under 24.6 lbs. Hope this helps.
    Quote Originally Posted by Dan Gerous
    From my experience these #s seem extremely generous. I think you could add at least a pound or more to each of those.
    Stock 06 1000 was 28.5#, med frame
