Results 1 to 5 of 5
    What air pressure in your RP23 on your Rush?
    Just trying to set this thing up and want to see what pressure others are running. What's a good starting point.
    I'm 185 lbs, Size Large Rush.
    Thanks.
    I'm 160lbs on a large rush and I run 120 psi. So for you I would recommend starting at 140-145psi.
    Mar 2006
    I'm around 180lbs and I run 155psi. The ride is really smooth, it could use a little more but susp. bob doesn't bother me on this bike, I guess it's the single pivot design cause I hated bob on my older FSR bike.
    I'd say start at 160-165psi and adjust from there.
    Reputation: Wick's Avatar
    Apr 2005
    171
    171-172 for me SSC and I'm 185-189lbs.
    Thanks for the info.
