Results 1 to 11 of 11
    Is there a specific Q-factor needed for XX on Scalpel?
    the wider of the two. i can't remember what the mm is but i know it's the wider.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    wider is 164
    Reputation: lowpsihighspeed's Avatar
    May 2010
    Thanks Eli and JV, that helps. Now back to working on getting my frame!
    Highline Search Group | highlinesearch.com | LinkedIn | Outdoor & Sporting Goods Recruiters
    Reputation: dblvanos's Avatar
    I was just wondering the same thing, we need a group start a group buy on xx
    I am running a 156 with no problems. Plenty of clearance even for a neoprene chain stay protector.
    Kam
    Kam is offline
    A hopped on pop.
    Reputation: Kam's Avatar
    Quote Originally Posted by dblvanos
    just give larry a call at mtnhighcyclery...no need for a "group buy", his prices are great.
    just bought a 1x10 xx drivetrain from him, cheapest anywhere!
    "forget kings...forget hadleys......they all have crap engagement. just run your bike fixed gear." - FoShizzle
    Quote Originally Posted by Kam
    Thank you
    Reputation: wannabeRacer's Avatar
    what about for 2011 Scalpel as I'm thinking of getting one, would an XX 156 Q factor fit?
    Quote Originally Posted by wannabeRacer View Post
    I've investigated this and from what I found out the 156Q will fit with about 2.5mm to spare. You may need to add BB30 nylon spacer to be sure the crank is centered in the frame. I intend on running 156 Q on the 2012 Scalpel I have on order. Same frame as the 2011.
    I'm Riding It
    Apr 2005
    Are you guys talking about the 26 or 29 wheeled Scalpel?
    I am curious as to if a narrow Q-factor XTR crankset would fit on the Scalpel 29er I have on order..
    www.bikeride.ca
    Alberta born-n-raised mountain bike racer.
