Results 1 to 11 of 11
    Sram XX 2x9 with X0 grips??
    anyone tried ...
    Sram XX 42/28t chainrings upfront (with Hollowgram KP128 spider )
    XTR 9 speed cassette (11/34) on the rears
    Sram X0 twist shifts/ grip shift
    XTR 9 Speed chain
    Will this set upwork and retain the notorious quick shifts on the Sram XX chainrings
    Im currently running a 2x9 (44/29 and loving it) just curious about the XX 42/28 chainrings.
    tia
    No
    I ran 2X9 last year with XO grip shifts XX Front Derailleur and a 26-39 XX crank on my Flash 29'er. I switched to full 2X10 this year with XO trigger shifters and rear derailleur and the front shifting was dramatically improved. I think it was too easy to get caught halfway between rings with the grip shifts. The triggers encourage a full shift movement and the chain is forced to move quickly between rings. Plus, having the trigger shifters already set up for 2 rings seemed to make everything work more clean and precise.
    Oct 2010
    Yup works nice.
    I'm using Grips converted to 10V rear now.
    Front, you only need to go full on, the end screws prevent you of doing wrong.
    No need for intermediate positioning.
    You go up or down and that's it.
    Quote Originally Posted by MirFlash View Post
    Yup works nice.
    so the XX 42/28 chainrings will work with a 9 speed cassette , a bonus if I can use my X0 gripshift
    thanks for the inputs
    I'm running xx 2x9 with x.0 grip shifters. Works great with 9 spd chain but even better with a 10 spd chain.
    Reputation: amillmtb's Avatar
    Jun 2005
    Works quite nicely...
    This thread needs some pictures.
    My set up:
    Hollowgram XX 26-39
    Sram X.0 Twisters
    Sram X.0 RD
    Shimano Dura-Ace front der
    Shimano XT 11-34 9sp. cassette
    KMC X9SL chain
    <a href="https://www.flickr.com/photos/39929703@N05/4918278987/" title="D5000 Shoot by mtbiker321, on Flickr"><img src="https://farm5.static.flickr.com/4141/4918278987_47aa7af70e.jpg" width="500" height="332" alt="D5000 Shoot"></a>
    <a href="https://www.flickr.com/photos/39929703@N05/4918879332/" title="D5000 Shoot by mtbiker321, on Flickr"><img src="https://farm5.static.flickr.com/4140/4918879332_74ee4fa837.jpg" width="500" height="332" alt="D5000 Shoot"></a>
    Quote Originally Posted by amillmtb View Post
    My set up:
    Hollowgram XX 26-39
    Sram X.0 Twisters
    Sram X.0 RD
    KMC X9SL chain
    Thanks- this answers my question
    EDIT: one other question I have is, do they make different Chainrings for GXP VS BB30
    tia
    Jun 2005
    Quote Originally Posted by spartan23 View Post
    tia
    Nope GXP and BB30 have the same rings. The only thing you have to make sure of is that they are not the custom for Specialized BCD. Standard is 80/120 and Specialized has custom rings for more teeth options, but the BCD is 64/104.
    Another suggestion would be to order the Specialized (old style standard XX 80/120 BCD) spider and ring combo, its only a few dollars more than the chainrings and it comes with the bolts. Its what I did because the major distributor in the US for LBS's (QBP) didnt carry bolts at the time.
    Hope this helps.
    Hope this helps.
    thanks for the tip- I almost forgot about the chainring bolts
    you da man
    thanks
    can sram red work??????
    Jun 2005
    Quote Originally Posted by de peng View Post
    I don't see why it wouldnt, but I have heard of flex issues with the Red der., because of the titanium cage, which is why I got a Dura-Ace.
