Results 1 to 5 of 5
    Which SLX from derailleur on 2010 Flash 1 ???
    So I just received a Flash 1 frame that I've been waiting on as a warranty replacement for the last 9 weeks. I thought I had everything I needed to get it built up but it appears that the SLX front derailleur i have doesn't fit between the tire and the seat stay. All cannondale says online is that the bike comes with a shimano SLX but shimano makes 7 variations of that model. It appears that I have little to no space there, is that normal? Anyone have pictures of one installed?
    2011 Cannondale Flash Carbon 2
    2010 Redline Monocog Flight
    2010 Specialized Roubaix Expert
    2011 Cannondale Jekyl Ultimate
    Reputation: brentos's Avatar
    Bottom Swing (high mount)
    It's a bottom swing on the Flash 1 29'er. I think a 34.6 clamp. Gets very close to the tire. A top swing (low mount) XTR did not work, it did rub the tire.
    Is it on a 29'er?
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    for me it's a direct mount type
    like e type , but no plate installed
    It is a 29er so the space is super tight. I'm having issues with the crank I was using so I just ordered an FSA Afterburner BB30 instead of messing with the adapters and hollowtech crank I have. Once I get it mounted it will be time to tackle the derailleur. Everything else is ready and waiting though!
    I should have been more clear, sorry, alloy Flash 1 not carbon.
