Results 1 to 9 of 9
    Reputation: lowpsihighspeed's Avatar
    May 2010
    Securing cables on Scalpel under shock pivot
    My cables are ratling around quite a bit under my shock pivot in the this photo. The manual shows a cable guide made to secure them, however mine did not come with one. What are you using to secure your cables?
    Attached Thumbnails Attached Thumbnails Securing cables on Scalpel under shock pivot-5-31-2010-10-18-59-am.jpg
    Highline Search Group | highlinesearch.com | LinkedIn | Outdoor & Sporting Goods Recruiters
    Mine came with clips to couple the housing together and I'm using the soft side of adhesive backed velcro under the top tube to keep the noise down.
    Reputation: Duncan1104's Avatar
    Zip ties?
    Reputation: Robin v Berkel's Avatar
    Quote Originally Posted by Duncan1104
    Zip ties?
    +1
    i us it to and works
    be careful of any rub under the top tube, I shortened my rear der cable housing,( the shorter housing must have changed the way it moved with the susp....) and with a couple weeks of riding had worn almost through the bottom of the top tube!!! I almost had a heart atttack when I noticed it.
    Reputation: amillmtb's Avatar
    Jun 2005
    Quote Originally Posted by bmxadian
    I would stick some frame savers under there...
    See you other post, are the unknows pieces the guide's youre missing?
    Tool
    Reputation: Pedalphile's Avatar
    Velcro is very useful for cable management.
    You can cut strips of the loop-side Velcro and stick directly to areas of cable that rub or slap the frame.
    You can also stick the loop and hook sides back to back to create a Velcro strip that you can wrap around the cables (loop side on the outside) - I found this very useful on the cables above the shock on my Scalpel - this minimized cable contact with the frame while keeping things nice and quiet.
    -Pete
    I can barely get my mouth around it.
