Results 1 to 3 of 3
Thread: Seatpost size
    Seatpost size
    I have a F9 and I am looking for a new Seatpost. From what I understand the size is 31.6mm
    My question is, will I be able to use a seatpost that is 30.9, or will it be too skinny?
    Thanks,
    Scott
    Reputation: MarinCRO's Avatar
    Jul 2013
    You need 31.6, although smaller diameter can work, but you need adapter.
    Reputation: Mr Pig's Avatar
    You can use a thinner post with a shim. By the time you add the cost of the shim you're as well just buying a post the right size.
    I've used shims before. I was a bit apprehensive about he idea but they worked fine. Try to find the longest one you can. Most are 80mm but some are 100mm and I think the more support you can give the post the better.
  1. what size seatpost clamp do i need
    By nauc in forum General Discussion
    Last Post: 03-09-2014, 07:24 AM
  2. Seatpost Clamp Size?
    By JRS73 in forum 29er Components
    Last Post: 07-19-2012, 10:10 PM
  3. Hot seatpost size
    By 12wheels in forum Kona
    Last Post: 11-23-2011, 05:23 PM
  4. Ibis seatpost size?
    By consolidated in forum Ibis
    Last Post: 09-18-2011, 09:56 PM
  5. Cannondale Seatpost Size Help
    By harmonf in forum Cannondale
    Last Post: 08-04-2011, 08:23 AM
