Results 1 to 3 of 3
    What It Be ?
    Reputation: ChrisJ's Avatar
    Aug 2005
    Scalpel Housing................?
    What size do I need? Or are there any adapters on this thing to take the cable guides down to 4.5mm? I'd like to run full length housing on the rear brake and derailer and i'd like to avoid using an adapter. Any ideas guys?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    You need a few of these:
    Any LBS should have them.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Reputation: HAL 9000's Avatar
    I got tired of the brake and shifter cable slapping against the underside of my top tube as I rode so I snapped one of these on them right under the frame shock mount and that has solved the annoying cable slapping sound.
    Jagwire Cable Cross/S-Hook
    https://www.jagwireusa.com/en/cablehousingguides.html
