Results 1 to 6 of 6
    Removing a Lefty Speed SL and XC3 SI stem from a Rush Carbon
    The title says it all!
    I searched on this cannondale forum for tips an how-to's on removing a Lefty, but all I could find were topics on removing Lefty's with older (detachable) clamps and with non-SI XC3, non integrated forktube-stems (the one with a shaft).
    So:
    1. How do I remove a Lefty Speed SL and integrated XC3 SI stem from a Rush Carbon? With the manual, I already got so far: remove bottom cap and remove clamp screws. Now I can turn the Lefty independant of the stem . But then, the XC3 SI stem just WON'T MOVE ! In the Lefty manual, they use a special tool to remove the stem (KT020). Do I really need that tool? Now I try to pull out the stem, but it's kinda stuck (or my arm muscles are extremely weak ).
    Any help?
    2. If the tool KT020, does someone know where I can buy it online (or in Belgium, Europe)?
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    try with an plastic hammer from bottom
    Quote Originally Posted by eliflap
    Won't go: the forktube of the stem is half a centimeter shorter than the head tube. If I'd bang it with a hammer, I'd hit the frame at the bottom of the head tube
    FIRENZE rulez !!
    yes i know the problem , i solved in this way..
    on my bike for lefty removal i do this:
    pull off down cap ( to be unscrewed) of combo stem/steerer
    insert inside of steerer tube of frame a plastic pipe with a large diameter similar to hole
    thah hit with hammer gently from bottom to top
    combo went out , lefty removed
    maybe , also the hand grip of hammer can be used instead of plastic pipe , and hit on the hammer with another hammer, metallic too
    eliflap, it might be tough to get if you're in europe, but there is a perfectly shaped plastic/rubber tool that cannondale sells for this purpose. i was similarly confused the first time i took my fork off. i used a large socket and a socket extension to pound it out. good luck with your tuning.
    FIRENZE rulez !!
    oh well here in italy , it's difficoult to get bike of cannondale , tools it's impossible ...
    only 1-2 shops have normal availability of tools ...
    you're welcome , but i crashed into shore with wheels ...
    no decisions about hubs ....
