Results 1 to 5 of 5
    Nov 2007
    Reducer Headset for A Rush
    Just to clarify, will any reducer headset work in a Rush frame or do I need a special Cannondale one?
    The Cannondale specific headsets refer to headshock not lefty frames.
    Yes, the one i use is made by fsa.
    Nov 2007
    Is that yes you can use any headset or yes you need a specific one?
    Ta.
    KTL
    KTL is offline
    You can use any 1.5" headset (for the use of 1.5 forks), or any reduser 1.5" to 1-1/8".
    I just removed a FSA reduser headset from my Prophet frame (to fit a Lefty), and was scared by the weight of it, more than 300g for a headset, that must be a record. (Compare to about 100g for a complete Cannondale Si headset).
    Nov 2007
    That's why I want to replace the headset on mine the stock FSA reducer is so heavy , the crown race must way 100g alone.
