Results 1 to 10 of 10
Thread: Prophet weights
    Rat Fink
    Reputation: mbmojo's Avatar
    Prophet weights
    I saw in another post the weight of the 2000 is 28.7 or something. Please correct me if that's wrong. Does anybody know the weight of the 1000?
    Reputation: MarkHL's Avatar
    Quote Originally Posted by mbmojo
    Off the Shelf with the heavy Maxxis Highroller tires (900+ grams) 31.5 pounds. I was able reduced mine to 28.5 by using Crossmax SL rims, Continental Vertical Pro tires, and Eggbeater pedals.
    The Prophets design that allows it to climb and descend so well easily makes up for the penality in weight. Certainly not a great XC bike, but just an overall good ride. Bike feels very balanced at slow speeds (i.e., technical sections of a climb).
    Reputation: DoubleDutch's Avatar
    Prophet 2000
    Hi mbmojo,
    The weight of my 2000 is 11.75 Kg / 25.9 pounds.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Quote Originally Posted by *Double Dutch*
    Hi mbmojo,
    But your's is speced closer to the Prophet 4000 Double D!
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Your right
    Your right Dan ..it's almost a 4000...
    But I'm still waiting on my FSA K-Force cranks...
    DD
    Hi mbmojo,
    What's the difference between the fork weight of a carbon and alum (steel?) lefty fork?
    LA CHÈVRE
    Quote Originally Posted by MarkHL
    Lefty Max Carbon SPV Evolve with Ti spring (Prophet 4000): 3.85 lbs.
    Lefty Max Carbon SPV Evolve (Prophet 2000 and 4X): 4 lbs.
    Lefty Max SPV Evolve and other Lefty Max (Prophet 1000, 800 and 600): 4.35 lbs.
    All according to Cannondale.
    virgilus
    Apr 2005
    if my shop is corect your should be around 32 pnds stock
    Jan 2005
    Prophet Weight
    I built my prophet custom with the following comopnents.
    XL Frame,
    Swinger 3Ways
    Lefty Carbon/TI
    CrossMax SL wheels
    XT Crank, XTR front/rear
    Sram Shifters
    Easton monkey lite riser bar
    Short Stem (100 mm)
    WTB velociraptor Tires
    Shimano 959 pedals
    Scale is at 27Lbs, not too bad for 6" of travel.
    Will I be able to save some weight by switcing to UST tires?
    LA CHÈVRE
    Quote Originally Posted by East Coast Bomber
    It depends what is your setup now. I used to ride tubed tires, around 600grams with 200grams tubes. I now ride 665grams UST tires (with a few grams of Stan's) so I do save over 100 grams a wheel. Of course, my XM819 rims are probably heavier than my old rims so it might be equal but you already have the UST compatible wheelset so you probably can save some weight by going UST.
  1. Jekyll Design vs Prophet Design
    By EdZilla in forum Cannondale
    Last Post: 05-10-2005, 07:30 PM
  2. prophet 600, trance 3/2, dakar xc comp
    By bigguppies92 in forum Bike and Frame discussion
    Last Post: 03-15-2005, 05:26 AM
  3. Pushed Prophet
    By DirtDad in forum Cannondale
    Last Post: 02-20-2005, 06:01 PM
  4. Prophet sizing:
    By Dan Gerous in forum Cannondale
    Last Post: 12-21-2004, 10:13 AM
  5. Jamis Dakar XLT 1.0 '04 or Prophet 600?
    By speedyslothracing in forum Clydesdales/Tall Riders
    Last Post: 12-07-2004, 01:59 PM
