Results 1 to 5 of 5
    PBR 140 Correct Castle too?
    I have a PBR 140 that I will be 29er converting, and simultaneously finding out why oil is slowly oozing from the top cap.
    "castle tools" seem to vary in price- could someone please specify which I will need for assembly/disassembly?
    While in there I plan on replacing the oil with 7wt Golden spectro, and updating the air piston, checking bearings...
    cheap:
    http://www.ride-this.com/index.php/c...ource=googleps
    not as cheap:
    http://www.bikeparts.com/search_resu...p?id=BPC136017
    expensive:
    http://www.universalcycles.com/shopp...s.php?id=18132
    ADIDAB
    Reputation: Steve_N's Avatar
    Quote Originally Posted by jthurd
    cheap:
    not as cheap:
    expensive:
    I have a PBR130 and bought the 'not as cheap' castle tool from Mendon. Works fine. Good to have a socket tool as well.
    Having just recently replaced the the stock oil for the Golden Spectro and the air piston I can vouch that it will work wonders...
    My LBS | Riding this and this
    Feb 2005
    Not as cheap.
    The other two will have you going WTF???
    Stick with 5 weight oil, the 7.5 will slow the whole fork way down, and unless you are a linebacker build guy, it's not really necessary.
    FYI Steve? Golden Spectro is the OEM oil, yours was likely just beat down from all your lovin'....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Will do, thanks fellas.
    So 5wt Golden spectro is OEM? Seems Steve and others noticed a difference in performance based on other threads. I just want to optimize the fork. I am 155, riding rocky front range AM stuff. Occasional XC race at Winter Park.
    Steve- fyi- Lefty will be going on a leviathan 4.0 pumped.
    Feb 2005
    I am 155
    Definitely go 5 wt....
    - FrostyStruthers
