Results 1 to 11 of 11
    Lefty Terralogic bearing reset...
    Has anyone actually done a bearing reset on a Terralogic lefty? I did this tonight and checked the measurement from top to bottom at a hair over 26 inches and it should be 27.4 inches (696mm)
    I'm not sure if I'm doing this correctly. I removed the split rings, and with the bike in a stand I used the weight of the wheel and compressed the fork and "slammed" the wheel downward. As I understand it this is correct - but I'm not sure just how hard to "slam" it, the manual just says "reset by pulling up hard a few times". The measurement didn't change at all and is 1.4 inches less then it should be.
    Please advise. Thanks.
    Feb 2005
    Quote Originally Posted by mattmor
    To paraphrase many a dirty movie, HARDER....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Apr 2005
    where did you find that info on how to reset the bearing on a fox lefty, I have one and never done that.....
    Quote Originally Posted by sebastian21
    I called Cannondale tech support and they emailed me a .pdf. Shoot me your email and I'll forward it to you.
    I have been riding a Rush w/ the Fox Terralogic fork since spring of '06 and I never have checked to see if fork needs to be reset. Doesn't feel like its changed, but I guess I could measure it and see.
    Reputation: CactusJackSlade's Avatar
    Breathing new life into this thread with a question... can I get a copy of said PDF on the Terralogic reset info...and if not, any big issues on resetting the Terralogic Lefty that is majorly different from my PBR?
    I was planning to:
    Take off the air/compression adjuster cap, let the air out, unscrew the "strut leg top cap" and proceed as normal.... are a bunch of guts going to come spilling out? I don't want guts all over the place!
    Thanks to anybody that can answer this! (Mendon CycleSmith??!)
    Brian
    Largest NorCal XC Race Series
    http://www.bicyclingevents.com
    http://www.UavTechReview.com
    Best in the West!
    ballbuster
    Reputation: pimpbot's Avatar
    Wait... is it press down, or pull up? Or, are both correct answers?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    This might help for the Lefty Terralogic owners:
    2006 Lefty Fox Terralogic service instructions
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Feb 2005
    If memory serves, with a red pin spanner, you remove the middle ring in the top cap. Push down, and remove the split rings on the piece that pops up, then reset as normal.
    - FrostyStruthers
    I'm not sure how the Terralogic differs from the model in this video, but it's a very illustrative video nonetheless:
    (Sorry, can't post links yet. Hit up vimeo.com slash 24521433.)
    The PDF is what I was looking for.... awesome, perfect!
    Interesting, the inertia valve in the example photos looks exactly like the regular inertia valves on the Fox forks.... probably the same part number!
    Thanks again :-)
    Brian
    Best in the West!
