Lefty Qcho pumping down?- Mtbr.com
Results 1 to 2 of 2
    Sep 2017
    Before I go through the efforts of sending back, I was wondering if any has heard of this... After riding aggressively for a little while, the shock starts to pump down, almost all the way to the bottom of the stroke. Once in this state, the bike is almost unreadable because of bottoming and the drastic change in geometry. This could have been the cause of a coupla broken ribs from a high speed pedal strike that seemed impossible at the time.
    Since the shock will return to normal after being parked for an hour or so, I'm assuming air gets progressively pumped and trapped on the negative side.
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    Thatís the same issue I had with my Lefty PBR. Could be just a bad seal. Worst case scenario your lower needs to be replaced.
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
  1. Lefty Hubs, Lefty Hybrid to Lefty 2.0
    By DOUGD in forum Cannondale
    Last Post: 08-24-2015, 10:04 PM
  2. Lefty Carbon Issue Pumping Air Hard Time
    By Ginbraiba in forum Cannondale
    Last Post: 11-27-2012, 07:59 AM
  3. Replies: 8
    Last Post: 08-08-2011, 07:35 AM
  4. Replies: 1
    Last Post: 09-05-2006, 05:20 AM
  5. Replies: 1
    Last Post: 09-04-2006, 06:39 AM
Members who have read this thread: 14
