    Feb 2007
    Lefty not smooth???
    Brand new Lefty DLR2 that blew the cartridge. Anyhow, I repaired the cartridge to get me riding until the new one gets here (Thanks Craig from Mendon!). When I compress the fork it is kinda rough feeling. Not really bad but I do notice it is not buttery smooth. Looks like the bearings are in place, I lubed the bottom fork under the boot. Any thoughts? Can't really see it being the cartridge as it feels like it even when it is removed and I cycle the fork. Thanks
    Scott
    Feb 2005
    If your bearing preload is on the higher end, you start to get a bit of "gravely-ness". Nothing to worry about. They also tend to smooth out as they break in too.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Feb 2007
    When you say bearing preload are you talking about the air pressure? I was going to just ride it and let it hopefully smooth out. It's not doing anything "wrong" but just a little rough. Thanks
    Feb 2005
    Quote Originally Posted by shift96
    No, bearing preload is the tightness of fit between the roller bearings, and the races they sit between. Factory, or service person set, not a customer thing. Changeable if you want it plusher, but migration quickens with lighter preload
    - FrostyStruthers
