Lefty Hub Dimension
Does anyone have them? They aren't listed on the DT swiss calc page anymore, and I can't seem to find them on the web.
I assume you mean the Cannondale Si Omega hub.
These are the measurements that I have measured from the hub, they match the ones on the Sheldon Brown calculator available from the NoTubes web site.
Left Flange:
Diameter (dL) = 58mm
Center to Center (wL) = 18.35mm
Right Flange:
Diameter (dR) = 45mm
Center to Center (wR) = 31.56mm
S,mm: 2.5mm
http://sheldonbrown.com/rinard/spocalc.htm
- You may not post replies
- You may not edit your posts
Forum Rules
