Results 1 to 24 of 24
Thread: lefty fork 2013
    lefty fork 2013
    Hi
    this is the first time I post in the Cannondale forum .
    I have few questions for you Cannondale experts about the lefty fork.
    1) Does Cannondale offers fork only option? and if yes what s the price? ( I 'm interested in the new 2013 PBR 100 29 Hibrid.)
    2) Can lefty fork fit any frame with tapered HT or it needs to be 1.5 ?
    I m planning to build a Rocky Mountain Element 2013 as my race bike and the lefty forks look preaty nice and light .
    thanks
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    new - Dr. Cannondale
    scroll down to the bottom for the adapter,
    go to page 1 for the new 2013 hybrid lefty.
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    thanks for the link.
    What about hubs? I have an American Classic race 29 wheelset with 15 mm qr do you know if AC sell conversion kit for lefty or what are my other options in order to use a lefty fork?
    thanks
    I wanted to do the same with an Orbea or Cube....the guy at the bike store told me that it was not possible (he may have just wanted to give the easy answer). I think there should be a converter to fit 1.125
    If i m not mistaken I think I read somewhere that AC is going to offer lefty conversion kits for regolar hubs but on their site I can t find anything.
    does anybody know if I can convert a 15 mm AC hub for a lefty fork ?
    thank you
    Ridin' dirty!
    Quote Originally Posted by italianbike74 View Post
    thank you
    No, you can't....disc side the axle of a lefty is way bigger than 15mm....
    Dec 2004
    How can the new Lefty be set up for 650b? Is the only difference between the PBR 29 and 26 the length of the bearing races? If so, could the 29 races be trimmed to an intermediate length to work?
    This is for a Santa Cruz TRc that I'd like to set up as 650b with a 2013 PBR.
    Oct 2012
    Quote Originally Posted by cdalemaniac View Post
    I dont think it can be done, you have to have a specific hub for the fork.
    aka: SpeedyChix
    Apr 2005
    Quote Originally Posted by pinepig View Post
    Remove one internal spacer (if it's like earlier forks).
    Adrenaline junkie.
    2x "big c" and enjoying life.
    Dec 2004
    Quote Originally Posted by Overdrive View Post
    I don't think the new forks work that way.
    Live fast. die younG.
    Reputation: keeb's Avatar
    from bikerumor.com
    If you’re curious as to whether you could put a 650B wheel on this, Murray says you could put it on the 29er Lefty. On the 26″ model, you’d be cutting clearance really tight and it’s not recommended. They build in 20mm of clearance for a 26×2.3 tire at the top of the tire to the bottom of the lower fork clamp. That’s under full compression and deflection, so you’d have to hit something really hard, really fast and at an aggressive angle to get the tire that close, but on a 650B wheelset with a similarly fat tire, you’d risk hitting the tire on the “crown”.
    Reputation: poorboy006's Avatar
    It seems you can only order a 2013 130mm or 100mm in a 26 configuration. Will the 130mm take a 10mm travel reducer to get 120mm and better 650b clearence?
    Sent from my Comet using Tapatalk 2
    derp
    Reputation: danielsilva's Avatar
    Quote Originally Posted by poorboy006 View Post
    Yes, or you could get the 29er Lefty and remove spacers as they're the same Lefty
    2006 Cannondale Rush 650b
    2010 Cannondale Trail SL 650b
    2013 Norco Range Killer-B
    Not dead yet, just playin
    Reputation: ohpossum's Avatar
    Not so much with the 2013 models. The length of the bearings determines the axle-to-crown measurement at bottom-out. There's no spacers to add or remove (at least as far as I can tell). I suppose you could use the typical spacers to limit the travel on a 26er model to work with a 650b wheel but you'll loose the ability to to a bearing reset since that happens at bottom-out on the new models.
    www.msmtb.org - Mississippi Mountain Biking
    derp
    Considering dr-cannondale asked me if i wanted a 29er with reduced travel ( i told them i was gonna use a 650b wheel ) i just assumed the procedure was the same specially when they offer to change them to either 26 or 29er when buying one.
    Maybe they also change bearings ?
    Well I just got my 2013 lefty in. Configured as a 90mm 29er fork I loosened the top cap, slid the damper out and removed the 3 10mm travel spacers. I now have a 120mm 650b (20mm of room at full compression) 2013 lefty. Score!
    EDIT: still only getting 90mm travel at most....looks like its the Upper air seal that is still limiting travel...back to the drawing board....
    Crappy iphone pic without cartridge installed @ full compression....
    Dec 2012
    I have a Scalpel 26" (2012) and I want to assemble 650b/27,5" wheel in the new Lefty 2013 that I want to buy. But several people says that to use 650b in 26" frame I have to buy the Lefty 29" 90mm.
    The 29" Lefty will work fine but it will change the geometry os the Scalpel and I don't want that. The Lefty 2012 and before models can accept the 650b wheels, but the new models are very different, starting with the length (according to the Lefty owner's manual):
    - 2012 - 26" - 695mm
    - 2013 - 26" 100mm - 548mm
    - 2013 - 29" 90mm - 578mm
    Does anyone already try the new Lefty 2013 26" 100mm with 650b?
    Any photos of it and experience?
    Sep 2012
    You are one of the only people I have found with a 2013 lefty.
    I have one to and was just wondering if you have had any problems yet with water. I know they redid the whole lower leg so that water wasn't supposed to be an issue, however I was just wondering if you came across anything.
    Typo, it's supposed to be Trevor4
    By B
    Sep 2012
    I have one to and was just wondering if you have had any problems yet with water. I know they redid the whole lower leg so that water wasn't supposed to be an issue, however I was just wondering if you came across anything. I'm new to mtbr sorry for the double post
    By B
    So which 2013 carbon lefty is the correct one to buy? 650b on a 26 scalpel, with out changing the geometry, it was started on this post, but no conclusion??
    Did anyone try the 26 100mm yet?
    Any thoughts on which one to buy? if im going for 650b on a 26 scalpel frame!! anyone???
    Oct 2011
    Quote Originally Posted by tevor4 View Post
    Bump, for similar inquiry.
    I too am looking into a 2013 Lefty for my 650b Rush Carbon. I'd hate to lose 10mm of travel (if I go 100mm) but I am thinking 120mm on my Rush may not work with the 650b mod. Presently I use the Speed Carbon 110SL that came with the bike and it works great with the 650b wheel... clearance of a few mm's when fully compressed with a 2.3 NeoMoto tire.
    Hrm.
