Results 1 to 3 of 3
    how many chain links for a Scalpel?
    Dear Scalpel mates,
    what is your exact length of the chain? I know the theory to determine the length http://www.parktool.com/repair/readhowto.asp?id=26 but in my case it seems I cannot reach the right length. My drive terrain is not 100% functional and the length of the chain might be the cause.
    Thanks.
    Jan 2005
    If your mechanical skills compare to your spelling skills you'ld better take your bike to the local bike shop. But to answer the question, I follow the standard guidelines but instead of adding two links I only add one and a Sram quick disconnect link.
    I have 108 on mine and things work perfectly. If everything is stock from Cannondale, you should be fine.
