Results 1 to 6 of 6
    Reputation: Ray Lee's Avatar
    How to change the FR/XC setting on a Prophet
    I know how to do it but do I need to release the air in the shock first?
    Ray
    Reputation: Duncan1104's Avatar
    you need two 5mm hex keys. Just loosen up the bolt, pull it out, and move it to FR or XC, then tighten it up.
    Thank you, I did not not if the shock was "pushing" out in its normal position.
    Ray
    Quote Originally Posted by Duncan1104
    Reputation: amillmtb's Avatar
    Jun 2005
    thats a no, you dont need to deflate the shock.
    Yep, I got it....hahha good thing I asked here or you would be stuck seeing me in about 10 minutes
    Ray
    Quote Originally Posted by amillmtb
    got the dhr...
    Reputation: luseboy's Avatar
    Make sure you tighten the bolts up pretty tight. The first time I switched positions, I didn't tighten them up enough, and every time my shock returned to it's full extent, I got this clunking noise, it was very annoying.
