Results 1 to 7 of 7
    Feb 2006
    help with headset?
    recently purchased a 2005 prophet,does anybody have any suggestions on which headset to run?
    Can't stop the Prophet
    Reputation: brows141's Avatar
    Give us a bit more info like:
    Are you running a Lefty?
    Feb 2006
    going to be running a manitou breakout. it has an integrated headset from what i can tell. it just does'nt have bearings in it.
    Reputation: Ray Lee's Avatar
    Those will need to come out they are for the Lefty shock, I am pretty sure you fork has a 1 1/8 steerer if so you need a 1.5 to 1 1/8 headset like this.
    http://www.jensonusa.com/store/produ...it+Dl+15R.aspx
    Quote Originally Posted by fat mo
    It might have the lefty System Integrated cups in it still. My Caffeine hard tail did when I got the frame.
    Does the fork have a 1.5 steerer, or a 1.125? (1-1/8th) If its the 1-1/8th then I highly suggest a Cane Creek Double XC II Flush head set. I just got one and it looks great. The frame itself has a 1.5 steerer since that's what the Lefties use, but the head set I used is a reducer to 1-1/8th since my fork has that.
    Which you have determines which you need.
    IF you have a 1.5 fork steerer then find a nice 1.5 headset. I don't know much about those.
    But you do need to get those cups removed if you're not running a lefty.
    Edit: didnt see the above post with the FSA headset recommendation. That looks like a nice one too. The Cane Creek is about twice the price, but it is a GREAT headset! It allowed me to lower my front end a good bit for climbing. You may have different concerns since you're building an AM full suspension. I am jealous of your frame btw.
    Feb 2006
    thanks alot guys. you have been a great help in getting me headed in the right direction. i think i may have figured it out. thanks again.
    Jan 2009
    Prophet headset
    I own a 2006 Prophet. They use 1.5 steerers so for 1-1/8" steerers you use a zero stack reducing headset. The best one is a Cane Creek XX Flush II. You can also use reducer cups.
