Results 1 to 3 of 3
    Oct 2007
    Headset bearings for 2011 Jekyll
    I have a 2011 Carbon Jekyll and I want to fit my Lefty PBR 140 Max but the head set bearings don't match up, the SI 90 mm steerer is loose inside the existing bearings and the headset bearings from my 2009 rize are loose inside the Jekyll frame. Has anyone made the conversion and did you have the same problem?
    You need Cdale kit HD169. These are two Lefty/Headshok bearings. The ones that are currently in there are for a 1.5" steerer.
    Reputation: chick0's Avatar
