Results 1 to 2 of 2
    The endless excuses guy
    Gemini Frame Replacement Policy
    My bottom bracket on my 2004 Gemini (6 months old) was loose, took it to my LBS for repair, but they could not get it apart no matter what they tried. LBS made 2 call to the factory tech support and they advised him to contact his local sales rep for frame replacement. Not the solution I wanted, but OK.
    Here's the problem though.....LBS guy said they will replace just the front triangle, rear swing-arm not to be included. That just seems wrong to me. These 2 peices are the central part of my rig and have "worn in" together. If they are going to replace the frame (which is admirable), I think it should include the whole shooting match; front triangle AND swing arm.
    I would appreciate your thoughts on this.
    Press "1" for English. Press "2" to be deported
    Mar 2005
    Well, you can't really ask them to do more than replace the part that's faulty, can you? The front and rear don't really wear in together like the chain and cassette or something, your new front will work fine with your old rear.
  1. New CS policy scenario...
    By FatB in forum Ellsworth
    Last Post: 03-11-2005, 05:54 PM
  2. Cannondale's "Great" Customer Service
    By azonicbruce in forum Cannondale
    Last Post: 12-09-2004, 03:31 AM
  3. Cracked frame - replacement options
    By rpmrob in forum Trek
    Last Post: 08-10-2004, 10:01 AM
  4. Giant Crash replacement frame HELP????
    By MTBSWA in forum Giant
    Last Post: 07-24-2004, 06:19 AM
