FSI Di2 Cable Routing?- Mtbr.com
Results 1 to 13 of 13
    Dec 2012
    Hey,
    the FSI frame has an opening on the right rear chainstay for the RD, an opening for the front derailleur just above the BB on the seat tube and another opening somewhat under the BB under the downtube.
    However there is no opening around the headset. Does that mean I am required to route the cable from the handlebar along the downtube to the opening under the BB?
    How does the Black Inc. route the cable?FSI Di2 Cable Routing?-img_5787.jpgFSI Di2 Cable Routing?-img_5788.jpgFSI Di2 Cable Routing?-img_5789.jpg
    If you remove the upper most cable guide on the downtube, you will see the entry point for the di2 wire. Cannondale includes a di2 specific replacement cable guide that allows the wire to pass under.
    I installed my di2 completely internally. Entering at the top of the downtube, battery in seatpost, junction B tucked into the chainstay.
    Dec 2012
    Cool. Thanks. I will post pictures when done.
    Dec 2012
    What is the big entry point below the BB for then?!
    Dropper post
    Reputation: rumshcawheely's Avatar
    md,
    Would you be able to post a pic of your wire routing from shifter to down tube?
    FSI Di2 Cable Routing?-imageuploadedbytapatalk1428167190.509677.jpg no problem
    thank you!
    Dec 2012
    Here we go:
    FSI Di2 Cable Routing?-2.jpgFSI Di2 Cable Routing?-5.jpgFSI Di2 Cable Routing?-unnamed.jpgFSI Di2 Cable Routing?-unnamed1.jpg
    Quote Originally Posted by larsd View Post
    Here we go:
    There's a smaller version of the singular plastic RD/brake cable guides that are on the lower downtube on the FSi. Its made to be placed under the bolt of the derailleur hanger to guide the di2 wire to the rear derailleur. Works pretty well. Should be in your bag of frame parts that came with the bike.
    Aug 2019
    Does anyone run an internal dropper through the big port in the downtube (near the BB)?
    (i just got my alloy 1 2017 upgraded to a carbon 3 2018 after a cracked frame and would like to upgrade my external dropper to an internal)
    That hole is there for running an internally routed dropper. So yes, do it.
    Aug 2019
    Quote Originally Posted by aussie_yeti View Post
    thanks, I thought it had to do with Di2, but it seems OK, just need to find a nice way to attach the cable to the other 2 mounting points, the top 1 has 1 slot free, but the other 2 have a single sided clip. I think the best option would be to double up on those clips, right?
  1. Cable routing for IGH
    By seankanary in forum Frame Building
    Last Post: 11-29-2014, 06:22 AM
  2. Cable routing for ASR 5?
    By max_lombardy in forum General Discussion
    Last Post: 11-12-2012, 07:55 AM
  3. Internal cable routing as it relates to cable housing bend?
    By Drew Diller in forum Frame Building
    Last Post: 10-10-2012, 07:44 AM
  4. Cable routing on TBc
    By cornice6 in forum Santa Cruz
    Last Post: 08-20-2012, 05:06 PM
  5. SLR cable routing on a SL
    By hillbilly_hank in forum Ibis
    Last Post: 06-18-2012, 10:39 AM
