Results 1 to 14 of 14
    Reputation: devix's Avatar
    Front derailleur for prophet with double chainset
    Hello,
    I've replaced original triple chainset with double and have some concerns if derailleur isn't to high now (see pic), I wonder if in MX front del is on the sime height as in regular prophets...
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    You can bring it down a bit though...if you remove the derailleur you'll see some ovalbrackets in the back of it...if you unscrew those from the plate you can flip them and bring it down a bit that way... (maybe by 1/8 of an inch or so..)
    Or you just get a standard clamp on (31.8mm) which should be a problem to mount since you have plenty of room now to slide it down...
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    Reputation: amillmtb's Avatar
    Jun 2005
    Check your limiter screws, shift it to the 2nd gear (bigger of the two) and tighten the high limiter screw so you cant overshift and go into your bashguard. From the picture it looks like you have it shifted into the non-existant 3rd chainring. The picture also looks like the chain is rubbing the inside of the derailleur which would be solved by tightening your high limiter screw.
    Quote Originally Posted by amillmtb
    Thanks, but suprisingly this is 2nd gear and H limit screw is set as you described. chain is not rubbing, shifting works OK but I think shifting from 2 to 1 may work better if derailleur was lower, but as this is E type derailleur I cannot really move it up or down...
    Quote Originally Posted by cdalemaniac
    clamp-on might be way to go, but I still wonder how this is done in MX - do they have e-type or clamp-on? Prabobly will go to LBS and check it ;-)
    thanks anyway
    I have a 2x9xbashring set up on my Prophet and just use a a normal E-Type XT front derailleur with the limit screws set so it can only shift between the two chainrings. I didn't need to make any further modifications or adjustments.
    Avenger of Evil
    Reputation: 1440Brad's Avatar
    Quote Originally Posted by vitaccop
    Same here.
    Famous Last Words....."Hey, watch this!!"
    Quote Originally Posted by 1440Brad
    Same here.
    and does the gap between bash and derailleur cage look smaller than in photo i've attached?
    got the dhr...
    Reputation: luseboy's Avatar
    with my 2x9, i didn't even touch the limit screws. I just put on the bash gaurd and rode away. works fine.
    Quote Originally Posted by devix
    Probably about the same gap.. I can get a finger in there between the cage and bashring. My limit screws are set so I can only shift between the two chainrings- the shifter won't even click to where the big ring would be. I have an E13 32 tooth size bash, XT E-type front derailleur, and XTR shifters.
    Avenger of Evil
    It looks the same. I would take a picture, but the Prophet is apart for spring cleaning.
    I should have it together soon.
    Jun 2005
    Well you need to tighen the High limiter screw so you dont accadentally overshift and throw your chain into your ankle. Not tightening limit screws is not exactly a good idea.
    well, High limit screw is almost all way down, that one you see on the front plan is actually Low limic screw...
    Ok, thanks guys, the reason I asked is shimano usually recomends derailleur cage to be only few milimeters above big chainring... but as there is no big chainring in 2+bash setup it is slightly confisung.
