Results 1 to 11 of 11
    Fox Float RP23 vs Fox Float RP2
    Does it really make a difference having a Fox Float RP23 instead of a Fox Float RP2? Is it worth it to spend the extra money? Any opinions?
    Reputation: karlmichael's Avatar
    i would say no
    i would keep the stock shock until it broke and then send it out to Push industries and get it rebuilt for your body weight and riding style and get the pro peddle set for your ridding style too. or just have it rebuilt with all the normal bit and stuff. look them up on line.
    karl
    Reputation: nathanbal's Avatar
    Quote Originally Posted by LS39
    no ita not. they are the same shock. the only difference is the 3 v 1 pro-pedal settings the rp23 has.
    ok
    keep the one you have then
    I'm riding my first FS (Scalpel 3 2007). It came with an RP2 and when i'm riding on Pro-pedal, it's like if I was on my hardtail, and I weight 185 lbs. It's all I want... if I had an RP23, I would just let it on the same pro-pedal setting forever.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    anyone needs a 165 mm RP23 FOX new ?
    Bike without rear shock is lighter Eliflap?
    Just kidding. I like the work You did on Your Scalpel.
    Keep on posting pictures of Your bike and upgrades.
    FIRENZE rulez !!
    i bought for changing my DT ...
    but i know .... never put a heavier shock on my scalpel
    Reputation: presa's Avatar
    Sep 2003
    ELIFLAP-- I need a rp23
    FIRENZE rulez !!
    i have it
    Sep 2003
    New question here.
    How much??
