Results 1 to 10 of 10
    New question here. Flash Front Deraillier
    Going to order the XX front deraillier at Chainreaction for the Carbon Flash.
    Anyone knows which spec is correct?
    Is it the Spec 3 Direct Mount? What about the TP/BP option?
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    flash 26" has S2
    the 29er has S3
    which frame you have ?
    choose BP = bottom pull
    Thanks eliflap. Mine is a 26". So isn't it S2 BP?
    BTW, I saw there are seperate models for 42-28 and 39-26. Is there a difference?
    FIRENZE rulez !!
    Sram XX has various types ... avery one is done to perform as best shifting performance
    so , related to which number of teeth are you planned to use , you must do the choice
    with a 40 or 41 or 42T big ring must use XX S2 BP 42-28 type ( pictured )
    with a 39T big ring or below a XX S2 BP 39-26 type
    don't be scary of number of teeth, i use a 40-26T ring with the derailleur pictured ( 42-28 type ) and it works fine.
    which combination of rings are you mounting ?
    I will mount the 39-26 combination. So I think I have to order the XX 39-26 S2 BP?
    Thanks eliflap. Your info is helpful.
    Cannondale Maros Team
    Reputation: vladxc's Avatar
    Jan 2009
    On a Flash, can be used a XTR or XT E-type whitout the mounting plate? is the same? I wanna get a Flash but I don't wanna pay so much for a XX FD
    FIRENZE rulez !!
    Quote Originally Posted by vladxc
    yes but you need some spacers .
    mmm please , saving more money waiting maybe a month more but try XX
    FIRENZE rulez !!
    Quote Originally Posted by jcb787
    correct
    Jan 2009
    Thank Eliflap
    FIRENZE rulez !!
    http://www.cannondale.com/usa/usaeng...supplement.pdf
    page 7 , check what you need , #KP123
