Dyad rt2 issue- Mtbr.com
Results 1 to 7 of 7
Thread: Dyad rt2 issue
    May 2020
    Dyad rt2 issue
    I just went to set up the sag/pressure on my DYAD RT2 shock on my Cannondale trigger but when I tried to release the negative chamber it started spewing lube/oil. Is this potentially because of a leak inside the shock? Has anybody else had this problem?
    Thanks in advance!
    Sep 2014
    There's some oil in there for lubing the seals but there may also be a leak. Once enough oil has leaked in the air chambers, the steel shaft will stay partially exposed even when the shock is aired up at the correct pressures: then it will be time for a service. Until then you'll be fine.
    May 2020
    Quote Originally Posted by romphaia View Post
    There was a decent amount of oil that came out (2 oz) immediately when I tried to release pressure so I stopped as quickly as I could and I'm afraid of losing more oil if I continue the process. Not sure how much pressure I lost by doing that so I guess I'm not sure if it's alright to ride still. Any suggestion?
    Sep 2014
    If oil leaked from the hydraulic circuit into the air chambers is normal that it leaks when pumping air. However it's probably better to keep it in there, or the air spring may become too linear and bottom out easily.
    Just pump it up and check if the shaft stay fully inside the shock body (probably not if it leaked so much oil...)
    May 2020
    I know the manual says to release the pressure in the negative chamber prior to filling up either of the chambers with more air. Will there be an issue if I just go ahead and fill the chambers without releasing the pressure first?
    Sep 2014
    Lay the bike on the side or upside down to avoid spilling out all the oil, cover tha valve with a cloth and release some pressure (you don't need to empty it completely, as long as it's lower than the positive).
    When inflating the positive, make sure the pump connector is threaded all the way in to the stop to engage both valves.
    If the shaft remains exposed the shock is still usable, you won't damage it but it won't perform at its best.
    May 2020
    Awesome! That seemed to do the trick. Putting the bike upside down allowed me to completely release the air in the negative chamber. It looks like the shaft is fully retracting too. Thank you for the help!!! I really appreciate it
  1. Fox Dyad RT2 top out sound issue!!!
    By wt_yp in forum Cannondale
    Last Post: 11-14-2013, 06:57 PM
  2. fox dyad rt2 - clank sound in elevate mode
    By radiomir79 in forum Shocks and Suspension
    Last Post: 03-17-2012, 01:26 PM
  3. Fox Dyad RT2 Issues???
    By Pike14 in forum Cannondale
    Last Post: 02-02-2012, 03:24 PM
  4. Custom Tune DYAD RT2? Any Feedback
    By mud0shark in forum Cannondale
    Last Post: 10-04-2011, 09:11 PM
  5. 2011 Jekyll DYAD RT2 Build Error
    By dkestar in forum Cannondale
    Last Post: 07-28-2011, 04:42 PM
