Results 1 to 5 of 5
    Jun 2012
    Crank removal question. . .
    I wanted to upgrade the fsa 386 crank that came on my 2011 Flash 1 alloy with an x9. Is it as simple as undoing the 10mm allen on the driverside crank ? Do i need a crank puller or is it just remove the 10mm nut and tap out the other crank arm ? Thanks guys, just started to do my own wrenching and it seems like the cranks should be easy enough.
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    FSA should have a full PDF on their site re install w/ exploded diagram.
    But yes, the FSA SLK cranks on my bike remove as you suggest.
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
    Jun 2012
    Thanks Stumpjumpy, I saw their website and it has directions for installation of the cranks. On a side note it mentions that u undo the 10mm and it should come out. Its crazy bc when i call my lbs, they tell me that i prob would need a crank puller. Forums are usually the best place for accurate info as we are all owners of the bikes and many of us experienced these things firsthand.
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Just a note, you might need a hammer on the 10mm allen key!
    Mine was tight as hell!! Once loose, the whol crank will come off, no puller needed!
    Jun 2012
    Quote Originally Posted by Flying_Scotsman View Post
    While doin some searching online, i came across a few threads that described how tight that 10mm allen was. Hopefully the lbs torqued it correctly when assembling my flash... thanks for the tip !
