Results 1 to 8 of 8
    Jan 2009
    Chris King Inset on Rize?
    Hi guys and girls, does anyone know if the Chris King Inset headset fits on an '08 Rize?
    T.W.O.
    Reputation: mimi1885's Avatar
    Doubt that, unless they have inset 1.5", the only thing I see on the site are the 1-1/8, and tapered. The 1.5" Kings should fit though.
    Jan 2009
    My stem is 1-1/8th, it's tapered steerer as far as I'm aware. I assume that means it will fit?
    T.W.O.
    Unless Cannondale change there MTB design, most if not all of there mtb are one-point-five headtube. I own several cannondale mtb, none are tapered or 1-1/8".
    What you may have is the Headset reducer from 1.5"-1-1/8". Check with your LBS, I think the King 1.5", or a devolution is your answer, not the inset.
    Jan 2009
    Cheers mimi, I suspect you're right about the reducer, it's a lefty thing isn't it? I'll check with the LBS.
    Reputation: amillmtb's Avatar
    Jun 2005
    Cannondale Lefty steerer tubes are neither 1 1/8th or 1.5. They are 1 9/16ths. If you have a carbon frame, you need to use Cannondale's bearings. If it's aluminum, you can press in a King or any other 1.5 headset or devolution headset to make the bike compatible with 1 1/8th forks.
    Keep in mind, changing the fork could void the Lifetime warranty on your frame
    Hope this helps.
    The King will not work. That vintage Rize has a unique headtube size. The only way to make an 1 1/8 fork work is with the Cannondale supplied reducing headset. Nothing else will fit the Rize. It is not a 1.5 headset.
    Nov 2008
    I don't know about the Rize, but the 9 Cannondale mountain frames I've owned (4 Prophets, 2 1FG's, 2 Judges and an F600) have all been compatible with 1.5 headsets. I had a Devo on 2 of my Prophets and 1 Judge. I always took off the crappy Lefty and used a decent fork which requires a headset swap.
