Results 1 to 2 of 2
    Changing the orientation of the lockout lever on the lefty
    When my lefty is locked out, the little lever you turn to lock it out is pointed directly at the handlebar (12 o'clock). I want to lower my handlebar but am worried that the lower bar would interfere with the lever when the fork is locked. My primary concern is that the bar would get in the way and prevent the lever from being placed in the lock out position.
    Is there a way to change the orientation of this lever, so that's it's pointing to 10 o'clock instead of 12 o'clock when fully locked out?
    Thanks dudes.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    I'm not sure about every Lefty modles but the DLR2 lockout lever can be turned 180°, just read this to see how. Beware though, if you hit your knee when the lever is at 6 o'clock, it could hurt.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
