Results 1 to 10 of 10
    chainrings for hollowgram sl cranks
    I need some suggestions on chainrings. I have been running a 2x9 setup but I am not satisfied with it. I recently brought a new 4 bolt triple spider for my cranks, but need some suggestions on what chain rings to choose. I am currently looking at middle burn and race face chainrings so I can run 3x9.
    holowgram
    i mounted these in 38/24 on my scalpel 29crb
    not expensive and works very good
    ZORLONI S.N.C. di Paolo e Sergio Zorloni
    Feb 2012
    how about a set of xt ones, keep seeing them on ebay for about 50 brand new, i'm using the fsa ones that came with my triple hollowgram, theyre ok in the dry but get a bit of mud round them and they tend to keep hold of the chain and either wont shift well or worse they suck the chain up into the chainstay,
    is this about the 2012 hollowgram crankset ?
    diameter 80/120 ?
    i love this one but i need smaller ring than 26 on my scalpel 29....
    Unstable Corruption
    Reputation: 0xDEADBEEF's Avatar
    Oct 2011
    Greetings to hollowgram experts.
    Cannot post my own topic yet.
    I've got Hollowgrams with 39/26 XX rings and 120 bcd spider.
    I want to make it 36/22.
    So i need to buy a new 104BCD spider with new chainrings?
    will BOR LK 104/64 spider do the job?
    yes it will. BOR also make a range of 120bcd - 80bcd rings, but i'm not too sure if they do 36/22. they are very good rings
    Unstable Corruption
    Oct 2011
    it's 25T minimum with 120 BCD, not enough for me.
    And what about the tools i'll need to replace the spider?
    i need spider tool, and a new lockring? or may be i can re-use existing one?
    25t, i guessed 22t might be too small.
    if you already have the crank removal tool KT013 - yeah just the spider tool, you can certainly re use the lock ring. and apply some loctite 242, (i think)??? pdf guides are available on c'dale website.
    good luck.
    yes, loctite 242!
    Unstable Corruption
    Oct 2011
    thank you for your answers)
