Cannondale Trigger single chain ring conversion- Mtbr.com
Results 1 to 6 of 6
    Apr 2019
    New question here. Cannondale Trigger single chain ring conversion
    Hi All. I have a 2014 Cannondale Trigger Carbon 2 29er and want to convert to a single chain ring. The frame has an ISCG/ISCG-03 mount and I found a suitable chain ring and guide. Iím guessing Iíll need a new, shorter BB to align the single chain ring and guide. Thereís not much information out there on this particular conversion. Can someone please provide advice on which BB product/part number would suit? Thanks. Chris.
    Reputation: Josh_W's Avatar
    Aug 2010
    Your BB is probably fine - most direct-mount single chainrings will be offset to match your BB/crank type, so the chainline stays optimal. If you have a crank with a double spider, rings for the spider can usually be mounted on the inside or you can get a single-ring spider. At worst you'll have the same chainline as your outer ring has now, and can take some time to figure out what changes are needed, if any.
    FS: Cannondale Rush XL 24lbs
    Mar 2019
    The best conversion would be to a Cannondale Hollowgram Si crankset with single AI offset chainring. You will need the MTB Si Spindle 137mm length and the correct spacers 9mm on drive side, two or three thin spacers and wave washer on non-drive side. The Bottom Bracket, if BB30 or PF30 remains the same.
    Apr 2019
    Photo of setup
    Thanks Guys for the feedback.
    Here's the setup - embarrassingly unkempt.
    Cannosseur, you suggested purchasing a new crankset and an offset chainring.
    Would that successfully align the chainring, so that I can make use of a Fouriers chainguide, which attaches to the ISCG mounts, as shown in the photo?
    Is there a cheaper way to do this? Can I simply purchase a shorter spindle that can fit the existing SRAM cranks?
    Apologies, I've done DIY on everything else on my bikes over the years, other than the BB end.
    Mar 2019
    If it is BB30 then Cannondale Si Spindle, Crankarms, and Chainring will fit or sets from FSA, etc. are compatible or if you have Shimano compatible BB then several choices from Race Face, SRAM, etc. You just need to confirm your exact BB, spindle type and length for chainline offset, and your budget and make sure you get the correct spacers for each side. Good complete setup could start around $250, Cannondale Hollowgram Si complete set could run $600. Chain keepers from Shimano, MRP, Absolute Black, etc. fit the ISCG mounts.
    Apr 2019
    Bb30
    Quote Originally Posted by Cannosseur View Post
    Hi Cannosseur. Thanks for your help, it's really appreciated. It's definitely a BB30, I believe the cranks are Truvativ and so is the new chainring, uses a Race Face "bash plate" on the face of the chainring, as per original parts. I'd like to try and use as many of the original parts as possible, as they're still well and truly serviceable. Can you provide the details for an online supplier for a Cannondale SI spindle/spacers? I'm in Australia and getting Cannondale parts is sometimes difficult. Thanks again.
  1. Cannondale Jekyll 3 2015 Single Ring Conversion
    By jekylljim in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-07-2015, 10:55 AM
  2. Single chain ring vs stock middle ring and chain slap
    By Terranaut in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-07-2014, 11:55 AM
  3. Replies: 18
    Last Post: 04-24-2012, 10:14 PM
  4. Replies: 43
    Last Post: 06-14-2011, 02:47 PM
  5. change a 3 chain ring crank into a single ring
    By Djponee in forum All Mountain
    Last Post: 04-01-2007, 06:26 PM
Members who have read this thread: 11
