    Reputation: cengle33's Avatar
    Cannondale Rush 4 2007
    I'm getting a lot creeking out of my crank, is there any thing i can do to stop beyond replacing the crank? Any quick fixes? My Local dealer says this is normal sounds, i don't believe him.
    This isn't a solution to your problem, but I have the same bike and I have been getting the creaky cranks recently as well. The cranks are FSA V-Drive MegaExo. The creaking really kicks in when I am in the granny gear heading up a steep hill. Hopefully someone has a fix for the problem.
    I'd remove the BB, grease the threads reinstall and make sure it is tight, I had a bb once that squealed like a pig.
    Alrighty then. I need to replace the 2 small chain rings soon, so I'll get that all done in one shot.
