Results 1 to 5 of 5
    Cannondale Habit - can someone explain swingarm flex?
    Guys, can someone scientifically explain why swingarm flex on Habit is good? I just don't like the idea of it and this pushes me towards Santa Cruz 5010 as a bike for my wife.
    "Flow" is characteristic of the rider, not of the trail.
    Reputation: MarinCRO's Avatar
    Jul 2013
    It's a way to reduce weight and makes it less complicated and cheaper to produce.
    Scalpel has been using that for quite some time now and the movement at that part is minimal.
    btc
    btc is offline
    Mar 2006
    MarinCRO, is the trigger carbon rear swing arm flex in the same way?
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Yeti uses the same concept on the ASRC. So do a few others.
    Death from Below.
    Yes, it's well tested. In fact the old 26er carbon Scalpel had no pivots at all (just for the shock / linkage) so I wouldn't be concerned about durability. If it's anything like the 29er Scalpel then it will be incredibly stiff side to side, so I don't see much downside really.
    As for performance benefits, besides a weight saving, perhaps there is some leafspring-like behaviour from the flexing swingarm that is desireable?
  1. Cannondale Habit
    By guvna in forum Cannondale
    Last Post: 4 Weeks Ago, 10:41 AM
  2. 2016 Cannondale Habit
    By heyhay5168 in forum Cannondale
    Last Post: 08-22-2015, 10:50 AM
  3. How to Build a Bike Habit
    By mtbxplorer in forum Commuting
    Last Post: 07-27-2013, 07:33 AM
  4. Can someone explain "flex" to me?
    By GnarBrahWyo in forum 29er Components
    Last Post: 02-05-2013, 12:28 PM
  5. How are you supporting your habit
    By tplace in forum Arizona
    Last Post: 07-18-2011, 05:11 PM
