Results 1 to 6 of 6
    Apr 2015
    Cannondale F-400, replacing rubber boot
    Do I need special tools to replace the rubber boot on my 1998 F400?
    Thank you,
    David
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Nope. Unclamp single stem bolt, slide for out remove boot and replace. Ebay has lots of replacement boots for $21/shipped:
    Cannondale Headshok Boot Kit Fits All Head Shocks 5 Ridge Black | eBay
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Reputation: Piratemark's Avatar
    Apr 2015
    replaced my boot yesterday, ended up removing the sterring tube and all the main bearings races, was a pig of job i will say. the boot i got online for 5.69
    Apr 2015
    Thanks for replying. When you say "single stem bolt", I's assuming you mean the allen key bolt that holds the stem extension to the steering tube. I did remove that and then tried a few light blows with a rubber hammer but it doesn't want to slide out. Am I missing something here?
    Thanks,
    David
    Quote Originally Posted by Fulltimer View Post
    Thanks,
    David
    I am sorry - try removing the top cap above stem...
    Apr 2015
    As you can see in the picture, there is no top cap to remove. It looks like a special tool is needed for removal.
  1. Replies: 29
    Last Post: 09-25-2014, 06:47 PM
  2. replacing rubber ring for rear suspension with plastic tie?
    By weekendthrasher in forum General Discussion
    Last Post: 04-13-2012, 11:02 PM
  3. replacing rubber ring for rear suspension with plastic tie?
    By weekendthrasher in forum All Mountain
    Last Post: 04-10-2012, 03:53 PM
  4. replacing rubber ring for rear suspension with plastic tie?
    By weekendthrasher in forum Shocks and Suspension
    Last Post: 04-10-2012, 01:30 PM
  5. Replies: 3
    Last Post: 07-25-2011, 07:16 AM
