2019 Scalpel-SI with Lefty Ocho - Page 3- Mtbr.com
Page 3 of 3 FirstFirst 123
Results 401 to 551 of 551
  1. #401
    Jul 2017
    Quote Originally Posted by scalpel226 View Post
    Itís available as an aftermarket item already, just installed on my 2017 Scalpel Si.
    Attachment 1246573
    Attachment 1246574
    How much did it cost as aftermarket?
  2. #402
    Quote Originally Posted by kanetrader View Post
    fot you it fits, for me not.. strange.... I now run a 32, but would love to ride a 34 ......
    How close were you? I wonder if you could use a 3mm spacer?
    D
    Somewhere lost in the Bush!
  3. #403
    Quote Originally Posted by gustavo.ghd View Post
    Around US$ 1540 list price
  4. #404
    Delete
  5. #405
    What did you notice in regards to ride quality from the 2.0? Do you need to perform bearing resets?
  6. #406
    Oct 2015
    Makes up-hill much easier due to an empty wallet
  7. #407
    Quote Originally Posted by Howards View Post
    Did he pay with coins?
  8. #408
    Quote Originally Posted by osteo View Post
    D
    I was pritty close, but the chain ring was just a little bit hitting the alu protector at he high point... I dont know about a spacer... is there a link and maybe extended vieuw?
  9. #409
    I'll be working on my bike in a little while, will measure how much clearance I have.
    D
  10. #410
    Iím on XTR Ltd and it has spiderring 34t. No issues in clearance
  11. #411
    Jul 2017
    Quote Originally Posted by TurboKoo View Post
    But that isn't oval.
  12. #412
    I have a 36 Wolftooth on my bike and a 34 oval Absolute Black on my wifeís. Both are SI cranksets.
  13. #413
    Mar 2019
    Hi, I just got my first ride in today on my new Scalpel Si 4 Carbon with Lefty Ocho. I upgraded the bars to Renthal Fat Carbon Lite 40mm risers and Easton EC70 stem and seatpost C Carbon so it is very lightweight for the standard balistec carbon frame and alloy ocho. As a mature road rider I was looking for comfort and lightweight and it has both big time. I have already ordered Absolute Black 32T oval ring to go on spare Hollowgram SiSL2 cranks off my road bike. So far the Lefty Ocho is amazing in its performance, I will post a detailed review.
  14. #414
    Mar 2019
    Okay, here goes! Just took delivery of my new Scalpel Si 4 Carbon with alloy Lefty Ocho fork. I upgraded to carbon riser bars and stem and a carbon seatpost and a more shapely Fabric Radius saddle, so weight is a feathery-for-full-suspension 25 lbs. Had the dealership setup the fork and shock with initial sag settings and a couple curb rolloffs for rebound, set the tires at 29 front / 33 rear. At 5'8 1/2" and 170 lbs. the medium frame is a perfect fit. Full disclosure, I am not an XC racer or marathon trail rider, I am a 59+ year old avid road rider with lots of new opportunities to ride gravel roads, rails to trails, light XC trails, fast rough paved paths, as well as singletrack at many area parks. So, I am reviewing the Scalpel Si for versatility in a lightweight, short travel trail bike and not as a XC racer, at which it already excels.
  15. #415
    Mar 2019
    The Scalpel Si is already well known to Cannondale fans as their world class full-suspension XC race bike, very lightweight and capable, with Lefty fork in most cases. The new for '19 Lefty Ocho is a significant refinement of the mono-strut front end on an already excellent frame and single-pivot, flex-stay rear end. Although fork and shock are 100mm travel on the XC race models, up to 120mm fork and 115mm travel shock are easily fitted and come on some versions. This is part of what makes a Scalpel, and other similar platforms, excellent short/mid-travel light trail bikes with the feathery weight of a XC racer for easy pedaling and the grip and cush for light to medium trails. There, the secret is out, a lightweight full-suspension XC bike trimmed out for a bit more travel, wider tires, comfy bar angle, etc. makes a fantastic general gravel road and light trail bike for non-racey adults.
  16. #416
    Quote Originally Posted by jschoef View Post
    It's as stiff as Lefty 2.0 , but more plush and significant improvement in small bump sensitivity, easier to obtain full travel during the ride. Needle migration still there, as long as you set the correct air pressure, the bearings are being reset during the ride when you bottom out the fork, so no big issue for it. Lighter feel at the front end, results in better cornering and sharper turn. Great upgrade for the Scalpel Si, makes the bike more fun to ride.
  17. #417
    Mar 2019
    As to specifics, I took my new Scalpel Si with preliminary setup today to a local park with a variety of paved paths, dry dirt forest trails criss-crossed with logs and limbs, and rocky single-track worthy of a DH rig and body armour. I tested the travel of fork and shock and compression and rebound dials carefully several times as I began to progress to bumpier terrain, trying to balance the two as best possible as I got the feel of their reactions. The Lefty Ocho up front is the compelling new interest so let me describe it first. Very smooth on small hits, very solid feeling for its equivalent weight/travel class. The new cable operated remote control is an important update and works not as a full lockout, but as a dual-range compresion control which essentially twists the master compression knob atop the strut four clicks higher, or about a third of its range increase. This means that you can tune the range on the fly by reaching down and turning the dial's range and then control it up or down four clicks up or down with the remote. Mated with a 2-position remote rear shock they both operate similarly, providing a very tuneable dual-range suspension front and rear. That is arguably superior in useability and hardware protection to full-lockout systems and surpassed only by active systems. So, the Lefty Ocho once setup carefully over several static and dynamic tests in the open setting took about 140psi to support my 170lbs. it seems to want just two or three more psi than recommended but then feels quite plush and uses most but not quite all of its travel over heavy hits. The remote actuated firm-pedalling mode makes a noticeble but not mandatory difference sprinting on flats and climbing, honestly the front end is very stable just left in open mode. What is impressive is the combination of super smooth low speed action and solid, stable, bottomless feeling takeup of big hits. I am very far from an enduro rider and the Ocho saved my face and more as I pushed its limits over bigger rocks, nosestanding more than once the ocho smoothly took all my weight, kept me from going over the bars with no binding or bottoming jolt and smoothly rebounded me back up and forward. In over my head, clearly beyond the limits of my technique, the ocho performed beyond the call of duty by being very stable and forgiving rather than the tweaky, exotic racing fork some might expect. Once balanced carefully as to rebound reaction as well as sag, and that is very important, the rear shock Rockshox Monarch RL worked excellently. Took two or three small incremental adjustments and ended up with around 155lbs. just less than the initial recommendation to get 25-30% sag which felt plush but supportive and matched closely the feel and reaction of the fork. I can't stress enough that small changes in the suspension setup can make significant differences in performance and balance front to rear is critical. This is a thoroughbred racing platform as sensitive as it is capable. Rebound settings came in just on the light side with three to four clicks in from open for the Lefty and four to five in for the shock for nimble reaction over roots and rocks. In a nutshell, after one brief first day test ride, I am very pleased and proud of the Scalpel's performance over a variety of surfaces, amazed by the super-smooth Lefty Ocho fighting well above its travel class, and looking forward to riding more trails! Stay tuned for inevitable further upgrades!
  18. #418
    Quote Originally Posted by Cannosseur View Post
    Thanks for the excellent, detailed ride report!
  19. #419
    So on the 2.0, the migration doesnít self reset on bottom out as it requires significant force. So on the Ocho, it is easier?
  20. #420
    no its the same. the ocho is less likely to migrate because all the bearings are tied together. All 3 sets have to slip at the same time. In the 2.0 only one out of the 4 needed to slip.
    The ocho is less stiff than the 2.0. Don't even go there. Cannondale even says it's less stiff. It's immediately noticeable, but it's way lighter.
  21. #421
    Mar 2019
    Cannondale cites 14% less torsional stiffness as adding forgiveness under cornering as tradeoff as well as lightness. After two short test rides I agree the Ocho is plush on small hits and uses 80 - 90% of its travel over a moderate mix of bumps but feels quite smooth, suddenly progressive and relatively "bottomless" at max compression. It gives the impression of being a 120mm shock in a 100mm travel body. Perhaps most importantly it seems very smooth and very supportive in the middle of its range cruising over small to medium hits at speed, as noted using quite a bit of its travel because of its low stiction ("shaft action slipperiness"). So, as appropriate, for fast smooth to medium smooth XC tracks the Ocho should deliver outstanding performance and still be capable on the more gnarly technical sections for its weight.
  22. #422
    Mar 2019
    A couple more follow up notes after a couple more rides over a mix of suburban paved paths, construction site gravel and dirt, curb jumping and grass banks, the Scalpel definitely excels at light bumps at a brisk pace, smoothing out broken pavement and curbs without missing a pedal stroke. Feels almost like a road bike in weight and acceleration considering the 2.25" tires. Compared again briefly at the dealership to an alloy Scalpel 5 with the Lefty 2.0, I would agree the previous version feels a bit stiffer but not as plush over small hits and a bit heavier in weight balance to the front end. The Ocho may have a tiny bit more wobble type of flex under big hits or hard fast corners as they admit but has this super smooth lack of binding and wide use of the middle range of the travel that is part of its design's justification. I'm guessing the elimination of the upper structure by going to the single crown design lessened the strength but also shaved a lot of weight and is aesthetically quite sleek. I found that brisk light trail riding and suburban curb hopping just pedalling along seated is a delight, cruising over sudden bumps without missing a stroke. The Ocho again seemed to use around 80% of its travel over moderate hits but never felt like it hit bottom even riding over a 4" square curb. I'm guessing this is the Ocho mojo or its forte for its size and weight class is the way it seems like longer travel than it is but super soft at first then long smooth travel middle range with pretty quick rebound, then ramps up quite progressive at the end of travel. This makes it feel like it has slightly longer smoother travel than other same length 100mm forks. Again, I am more a roadie and gravel rider so I am describing how it feels to me compared to similar models with a fox 32sc or rs sid etc. I have tested.
  23. #423
    Thatís exactly what I feel!!
  24. #424
    Mar 2019
    Well consensus is good that the Ocho seems to be relatively stiff in its upper, being an upside downer after all, and particularly for a single-crown single-sided fork, in its weight and travel class and has plush small hit reaction as well as very smooth and solid support for all out action. This afternoon I had a young (17) very skilled (regional champ CX) rider take my Scalpel for a performance test over pavement, dirt, grass, curbs, medians, islands etc. wheelying and bunny hopping like a young champ. His comments were "really light for a full-suspension bike, handles killer like an F-Si and the fork is amazing for only 100mm!" he called out as he nosed it up hard onto the fork over a curb onto a grassy island, then let it spring back up and on to the next stunt. Fun to watch, the Scalpel with the Lefty Ocho can definitely kick some butt in the hands and feet of the gifted and I am more than happy as a path and trail cruiser with the light weight and excellent ride.
  25. #425
    Reputation: jjames55's Avatar
    Dec 2012
    Got a 2019 carbon 2 yellow/blue - fantastic bike..
    But
    Creaks from the bb like my old supersix
    This it the yellow/blue model... after one(1) day riding in the spring sun with some dirt on the frame, everything but the dirty areas have been very visually faded in color!!! Wtf. Has Cannondale not heard about UV resistant colors? I can't imagine what the summer sun will do!!!!
    Anybody seen this thing too? Of cause there is a exemption in the warranty rules against this - but this seems like a defect...
  26. #426
    Most likely needs grease at all pivots. Factory probably didnít grease. You need to follow the instructions on how to dismantle and grease.
  27. #427
    James55- welcome to PressFit. My Scalpel 2 was a thing of silence on the trainer for some time and then one day I thought I felt something strange while pedalling, looked down and thought I saw my foot shift laterally. Strange, I got off and was able to move the crank assembly 3mm side to side. Needless to say I was not amused.
    The axle/BB bolt had come loose. Dug up the install instructions, loosened the pinch ring, re-torqued the bolt, tapped with a mallet, tightened the torque ring (tapping it a bit tighter) and now I can hear it creak on the trainer when really pushing it, but have on ridden it on the road once and it was quiet.
    The instructions do say to apply grease to the mating surfaces if it creaks which once outside will see if it still does.
    Not happy to hear about the paint fade though... but then also not happy to hear about the seal leak in some of the Ochoís either...
  28. #428
    Reputation: BoostN7's Avatar
    Dec 2010
    Hey man, can see you're riding a race the same as me. Do you have anymore photos of it? Did you have to change the lockout system? The Scalpel race SI obviously has a hydraulic lockout switch which operates the Lefty and the rear shock, just wondering how you got around it as I heard the Ocho is cable only?
    and no, I am not missing the other half of my fork....
  29. #429
    Dec 2012
    Oh Yeah - mine ocho seems to leak oil also, a constant film on the lower leg... time to call the lbs i guess
  30. #430
    Dec 2012
    Took apart the SRAM crank and spider and greased it all up good - no difference...
    Then took apart the lower link pivot(?) and did the same, greased it up good and put it together again... - silence even when pushing hard
    So it seems like a sloppy grease job from the factory!
  31. #431
    Quote Originally Posted by jjames55 View Post
    Thanks James - first ride on trails on the bike for me tonight, will see what it is like. My trainer ride yesterday was creaky and seemed to be getting worse. Will check the torque on the crank bolt before I head out and if creaky creaky will grease everything.
    D
  32. #432
    Jul 2017
    Sounds like a common issue these days.. I used to own a 2016 Habit and the comments in the Habit thread mentioned that grease was lacking at linkges and pivots too.
  33. #433
    I gotta say.... DAMN! I love this bike! Much faster than my Niner was, quicker, smoother... damn skippy!!
    Iím changing out the rear hub going to put in the new I9 Hydra going from my Kappius with 240 pts of engagement to 54 or less with the DT Swiss is not even in the same ballpark for engagement.
    Also happy to announce no creaking on the trail, guess I just donít put as much power down riding in real life as I do on the trainer. Will still take apart and grease everything but at least it was silent on my maiden trail ride.
    Oh... and the 3 guys i rode by that commented on my bike... it was like a Mastercard commercial - Priceless!!
    D
  34. #434
    Quote Originally Posted by BoostN7 View Post
    You are right, I need to get a new rear shock as well. I have ordered the Fox Float DPS remote lockout shock, in the mean time, I am using DT shock with normal lockout. Once the Fox shock arrives, I will install it to work with the Fox PTU remote with Ocho.
  35. #435
    D
    Which Niner did you come from? I'm considering the Jet.
  36. #436
    Quote Originally Posted by bikenut316 View Post
    Jet 9RDO, it was the 2015 version which they have changed. One thing I found interesting on my ride was how light the Scalpel felt, but according to the scale it actually weighed more than my niner.
    The comparable bike now would be the RKT I think.
  37. #437
    Dec 2010
    I'm somewhat confused... do you have a photo of your setup? Trying to work out what I need.
  38. #438
    Mar 2019
    Whereas the previous version used a hydraulic remote, the Ocho employs a cable remote and comes stock with the Fox remote lever which is capable of single or double cable action (notice the second hole in the remote housing). So, you only need to get a remote-actuated shock like the Float DPS 2-Pos version and install the second cable from the remote. Also, although the stock shock spec is 190x46 (=100mm travel) a 190x51mm (=115mm travel) bolts right on a regular Scalpel Si and provides the extra travel capacity without the link or swing arm of the Scalpel SE. Note that the team bikes in most recent photos have the shock reversed so that the head of the shock is to the rear with the control lever/dial facing upwards, this allows the remote cable to run straight from the top tube opening back to the cable fixture on the shock instead of bending in a tight loop. I have ordered a Fox Float Factory DPS 2-Pos 190x51mm shock to employ this slick trick.
  39. #439
    Guess you are a lefty fan. lol
  40. #440
    Same with mine, started leaking seriously after about 200 km. LBS sent it back to the dealer, apparently it's just a problem with the seal. Should be back begging of next week.
    Other than that I'm super happy with the bike (carbon 2).
    Regarding the chainring size - I swapped truvativ for hollowgram cranks from my 2016 scalpel and I'm running it with 34 oval absolute black ring. LBS had some problems fitting it, as I also have a power meter on the left arm, but somehow they managed it. Not much clearance on both sides but no rubbing either.
  41. #441
    Jun 2010
    I am thinking about buying the new 2019 SCALPEL-SI CARBON 3
    I am currently riding a 2014 Scalpel Team, Large frame, yet I am running the longer / raised stem and my seat post is offset all so I can ďsqueezeĒ onto my bike. Iím 6í1, 220 lbs. Big guy.
    My question is should I consider going for the XL frame as opposed to the Large frame and then modify to a longer stem, seat post etc.
    I have always been told if possible its always better to fit into a smaller frame if at all possible yet as I get older 56, ,not sure which direction to go.
  42. #442
    Mar 2019
    At 6'1" you are textbook for a Large but depending upon your inseam in proportion which will dictate your standover clearance. If you can stand comfortably over an XL with just a smidge of crotch clearance you could consider it if you have really long arms and or torso. An XL would typically be for someone 6'2-3" and 6'4" and over J (XXL) but everyone varies in proportions. I highly recommend trying both at your Cannondale dealer.
  43. #443
    I'm 188 cm (about 6'2), riding size L scalpel and it feels perfect. Stock seatpost, stem, etc.
    If you have access to XL, it's definitely worth trying. But if not, I would say you should be fine with L.
  44. #444
    same here, oil leak after a 1000km... back to lbs, who did as it was the first time, but I know more ocho owners has this problem. hope it will be solved soon and def. but very happy with the Scalpel, super light feeling in steering and super fast ridable bike.
  45. #445
    Mine is also sent for service due to oil leak. About same kmís with 1000km on the clock.
  46. #446
    I wonder if it was just someone with long pointy finger nails on the assembly line?
    At 1000+km hopefully that is after my first big race of the season.
  47. #447
    Nov 2018
    How often do you reset bearings on Lefty Ocho ? Mine comes short 1.5 cm after every ride, 2 cm after several rides. I'd say that is too fast. What can I do to prolong time between bearing resets ?
  48. #448
    Thats how the 2.0 is too. After 4-6 hours or riding I'm down 30+mm. The only way to supposedly prolong it is to ride it softer then you might be so you bottom out periodically on a ride to reset while riding. On the 2.0 this does not work as you need a significant hit with no air in the shock to reset it. How much force does it take on the Ocho?
  49. #449
    So, between what you are saying and what scalpel226 said a couple weeks ago ďIt's as stiff as Lefty 2.0 , but more plush and significant improvement in small bump sensitivity, easier to obtain full travel during the ride. Needle migration still there, as long as you set the correct air pressure, the bearings are being reset during the ride when you bottom out the fork, so no big issue for it. Lighter feel at the front end, results in better cornering and sharper turn. Great upgrade for the Scalpel Si, makes the bike more fun to ride.Ē
    Would it make sense if you wanted to reset it to remove all the air and do a couple full compression cycles through it? Kinda a reverse of resetting the bearings in Version 1?
    D
  50. #450
    D
    Yes, thatís exactly how you do the 2.0 and Ocho. You have to slam it though.
  51. #451
  52. #452
    2019 Scalpel-SI with Lefty Ocho-59498386_10156265548403059_7878524219204567040_o.jpg
    When I push the remote button to unlock the Ocho fork, the compression knob turns clockwise at the same time, that's normal. However, the compression knob doesn't turn back when I release the remote button for locking-out the Ocho. If you lock and unlock the Ocho few times, actually the compression knob is turned clockwise few times, it means adding more and more compression on it. Is there something wrong inside the lockout mechanism or compression knob?
    P.S. the compression knob screw is tightened to manufacturer torque 0.85 Nm
  53. #453
    Most probably the cap is tightened too hard.
  54. #454
    Not really!
  55. #455
    Off the top of my head isnít there a thin O-ring between the cap and the top of the Ocho? Might it be dried out or possibly pinched? I know the instructions were clear on torque for that cap, I tightened mine up just enough to seat the cap.
  56. #456
    Take off the cap, lube the seal with 2.5 wt suspension oil, tighten it just enough to seat the cap, no luck at all......
  57. #457
    When you LOCK the fork and the dial doesnít turn, is it actually locking out?
    I would disassemble and reassemble, making sure you lubricate the seal; as well as, making sure the return spring is properly placed and seated.
    WARNING: be careful when you disassemble, make sure its in the LOCKED position, as the spring preload can cause parts to fly...
    When you reassemble, donít torque the compression dial screw all the way. Screw enough to engage the splines and then seat the seal by turning the compression adjustment dial all the way clockwise and then all the way out. At this point, torque to 0.85 NM.
  58. #458
    Oct 2007
    If I remember correctly, you paid good money aftermarket for that Ocho. I would contact who you purchased it from.
  59. #459
    Quote Originally Posted by trauma-md View Post
    I will ask the local dealer try to disassemble and reassemble it and see how it goes, thanks
  60. #460
    Quote Originally Posted by norty_mtb View Post
    You are right, I will contact the local Cannondale dealer.......thanks
  61. #461
    Reputation: rupps5's Avatar
    The seal around the compression knob needs to be lubed. Put some light weight oil on the knob and work it into the seal. Also make sure the seal lip is not stuck under the knob.
    The spring release can be set to 3 different strengths of return. Factory is in the middle. You can set it to slow and that helps not move the knob out of adjustment.
    The problem is there is stiction between the knob and seal. When released quickly the knob does not break stiction and self adjusts itself about one click. Its a compromise, you need a good seal to keep dirt out but it needs to be lubed so it can turn (when its supposed to)
    Evolution Training Cycles
  62. #462
    Quote Originally Posted by rupps5 View Post
    Thanks for the great tips, I have done all of the above but no luck! Bring the bike back to the local Cannondale dealer, they swapped another compression knob on my Ocho, problem solved immediately! Would be tolerance or QC problem of the compression knob and make it very sticky! No idea at all indeed, as long as it works again, I wonít bother it.
  63. #463
  64. #464
    Quote Originally Posted by BorisGoreta View Post
    I was down an inch in 2 hours. I sent the ocho back again. I rode for 2 hours again and it had no or next to no migration.
    They took out a volume reducer. Also I believe the have new specs in adjusting the bearing pre load, when building and servicing ochos.
  65. #465
    I thought the bearing migration issue on the Lefty 2 had now been permanently resolved with the Ocho....seems not to be the case
  66. #466
    Oct 2015
    The major change was that they fixed the three bearing sheets together in a carrier.
    But if the factory pre-load is too slack, all three sheets will migrate together, carrier or no carrier.
  67. #467
    Mar 2019
    I can confirm also that as delivered my Ocho compression knob would bind slightly and not lock out properly but just move to higher compression setting by a few clicks. After removing it, lubing the seal with high quality light oil and gently retightening it the lockout and release work properly.
  68. #468
    Aug 2010
    I absolutely love mine. Finally rode it for the first time and it has a slacker feel to it. I had two scalpel si prior to this one and it does handle different. That ocho fork is very plush and with the vast majority of cross country bikes getting slacker and running 120 front forks this seems
    To trend that way as well making it more forgiving on the descents IMO.
    Attached Thumbnails Attached Thumbnails 2019 Scalpel-SI with Lefty Ocho-edc6668f-6efb-4174-b52f-89229a2fca8a.jpg
  69. #469
    New question here.
    Thought Iíd chirp on the thread today, I love my Scalpel! Thankfully no Ocho leaks (knock knock...) but had my first race on it on Saturday (Mohican) and once I got used to the slick rocks and roots with those tires it was a blast.
    Iíve done a changes to the bike, will start off with those:
    Absolute Black Oval 34t Chainring, loving it!
    Industry 9 rear Hydra Hub - damn skippy!! Loving the killer bees!
    Specialized Phenom Pro saddle.
    ESI Extra Chunky grips
    Magura Vyron Dropper - for use at Breck Epic this year, Iíll put it on about a month before so I can get used to it again.
    I think someone mentioned how pressure sensitive the Ocho is at some point, and I agree. I used a ShockWiz to help me tune both the front and rear and found I had a slight discrepancy in pressure readings between my shock pump and the Shockwiz - so when I prepped the bike for the race I think I put in about 4-5psi more than I should have which I noticed within the first few hundred meters one the single track.
    Now that I think about it, I was planning on giving pure rave reviews!! But do have another point to mention... as noted pages back, I built up the bike myself and pre-race prep for me is to take the torque wrench and go over every nut and bolt on the bike, every one gets touched. I found the lower non-drive side pivot bolt to be way out of torque - lesson for me reaffirms to check everything. Torquing it, also returned a creak I noticed when on the trainer, which means I will be taking the rear triangle off and applying a bit of grease.
    None of that is earth shattering, and could be the case with any new bike - but damn does it handle well!!!
    I Donít think this is a factor of the hub or maybe I have a better aero position (highly unlikely) but there was more than a few instances going downhill at Mohican that I would be behind other riders, tuck down and easily blow past them at the bottom of the hill, coasting faster and going farther, and nope, was not in their draft.
    Iím super pleased with the bike and considering it weighs more than my Niner did, itís hard to notice.
    Oh, also made a mount for a spare tube just below the water bottle cage, think Iíll make another to put my tools on the seat tube cage mount.
    D
  70. #470
    Shock Mount
    I've had my HM1 for a couple weeks now. I've noticed some bikes pictured have the shocks mounted with the lockout knob to the rear and some to the front. CDale site shows them to the front. I can see where the knob to the rear would make water bottle access much easier and less chance of messing w/rebound knob. Hoping this is a dumb question but is there any reason why I can't turn the shock around?
  71. #471
    Mar 2019
    Reversing the shock has no downside and more than one possible improvement. If a non-remote shock it is easier to reach the lever, if a remote-actuated shock the cable angle is straight rather than a tight loop.
  72. #472
    Oct 2007
    Quote Originally Posted by aminkman View Post
    You just need to be cognizant of the lockout cable if you switch the shock. Make sure it isn't rubbing on the frame as it moves when in the rear position.
  73. #473
    I moved it yesterday and will give it a go today. Much cleaner look and you can actually see the rebound adjuster without standing on your head. I'm sure the front bottle will be much easier to manage. Weird that this isn't the stock position. Unrelated - I do have an odd rubbing sound coming from the hub area. Sounds like brake pad drag but rotor is true. Anybody else hear that?
    EDIT: Definitely turn your shock around! Bottles are much easier to use. I don't have to look down to put them in, very natural now. Slightly less pressure to lock out
  74. #474
    So mine is a RS and there is always an oil ring on the stanchion after a ride which is part of the design...oil lube / bath. Turning it upside might make it so it isnít lubed???
  75. #475
    Nov 2018
    So my rear Hollowgram wheel snapped while descending on a rocky section on a marathon, nothing special, just rocks scattered around. On a really big rock sections I stopped and walked. Frame size is L and I am not that heavy, 77 kg. Do you recon this is covered by warranty ? Rim was not hit by the rock directly, it snapped by the effect of the force coming from the tire.
  76. #476
    Wow. I seem to think I heard these rims are not all that strong. Wonít know till you ask, take pictures of both sides, I wouldnít remove the tire till you take it to your store.
  77. #477
    This looks like failure to me. There should be an indentation impact site if itís from a direct hit. I agree with osteo, do not take the tire off or unseat the bead until you take it to your shop. Make sure you watch the process, you will want to know if there is seam on the inside of the rim in that spot.
  78. #478
    Mark the tire and rim with a single paint pen line before taking the tire off. It will give you the position that you are looking for.
  79. #479
    Nov 2018
    Just a quick question about warranty. If I bought my Scalpel in Germany can I warrant it in a shop that sells Cannondales in Croatia, where I live ? Are they allowed to say I have to take it back to a shop in Germany or they have to take it in ?
  80. #480
    it should be a worldwide warranty...
  81. #481
    It of course is world wide warranty. According to rules you should contact first to the place of purchase but you are allowed to take care of it at the closest shop. Bear in mind that since there can be different distributors so work related costs can make it so that they want you to take care of it in Germany.
    In my opinion thatís not warranty and you have just been able to get rock hit on your rim. Iíve seen those before and itís always like that.
  82. #482
    Nov 2018
    Thank you for your answers. Today I took a couple of more pictures in the sun. Please let me know if you think this is a warranty issue or some rock hit it on the side. Either way it is fine. If it was a rock then I'll keep my confidence descending with these wheels knowing they truly are hi impact carbon, just not when the impact comes from the side
    P.S. If this can't be warranted can I at least ride it on tarmac until new rim arrives, the tire still holds air, I mean the old rim is toast anyway.
    Attached Thumbnails Attached Thumbnails 2019 Scalpel-SI with Lefty Ocho-20190610_103906.jpg
  83. #483
    definitely do NOT ride the bike like that
  84. #484
    Oct 2015
    Erm yeah don't ride that unless you enjoy dental work.
    It's a warranty failure if you argue that it is. It looks like one. Only you know what you did with it.
    As you bought in De but are warrantying elsewhere expect to be treated like sh*t. Ask me how I know.
  85. #485
    Nov 2018
    I cleaned the area a little bit and judging by this image there is no forensic evidence that the rim has been hit by a rock, meaning I should be able to warrant this.
  86. #486
    I agree. The outer rim area would be marked or at least scratched in some way and the tire sidewall I would suspect would show lines of being compressed as well. Again, donít that that tire off when you take it in.
  87. #487
    Looks like an impact from a rock to me. Bottomed out tire, force through bead hook on one side because bike was at an angle and then the rim cracked. I've done it before although it's been either less damage and repairable or an exploded rim.
  88. #488
    I concur, direct impact on the tire with a rock causing it to bottom out...I doubt very much its a warranty replacement ...but hey, worth a try
  89. #489
    Nov 2018
    Just to be sure this doesn't happen again what pressures do you pump into rear and front tires ? I am running stock tires in tubeless configuration.
  90. #490
    Iím running 22-23psi tubeless, weigh 169lbs in my birthday suit, like to think of myself as a smooth rider and my local trails do not have a ton of rocks, particularly the sharp pointy rocks that cause damage.
    D
  91. #491
    Nov 2018
    I was running 24 in the rear tire.
    Aren't mountain wheels and tires designed to hit rocks all the time from all kinds of angles ? I mean this is what mountain biking is. Cannondale puts the same wheels on hardtails, how do they survive in that case ?
    My aluminum wheels survived 8 years on my previous Scalpel without any problems and are still probably running ( I sold the bike )
  92. #492
    Reputation: Flash29r's Avatar
    May 2013
    I think it was just bad luck and doubt they will warranty it. You may get lucky though. I have a set of Reynolds on my F29 and they have been through a lot of rock gardens with no damage at all aside from scrapes to the decals. I have the CZero rims on my Scalpel and they are good as well. Chalk it up to a freak thing.
    '18 Scalpel Si Carbon 2 Eagle
    '12 Flash 29r C3 with a few mods
    '10 Synapse 5 Carbon with a few mods as well..:)
  93. #493
    I have fitted these to my Spacecarbon WS3431 wheels since they cost me 1400 euros and I run 1,1 bar and 1,5 bar front and rear and do not want to damage the rims...besides all the other advantages that these tire inserts bring
    https://tubolight.bike
    https://youtu.be/HTXLBPeqQQQ
  94. #494
    I had a set of stans valors, those things probably took 100 rock strikes and were just fine. In one race I hit a rock at about 20mph, the rim just cracked and exploded into 4 pieces. All it takes is one hit the wrong way and they can break.
    I have to say I have had much better luck with carbon vs alloy though. Alloy rims were just constantly dented.
  95. #495
    Seems I am joining the club of those with the leaky Ocho
    Long ride yesterday (road/gravel as it turns out) and putting the Scalpel in the rack on the roof I noticed a thin film of oil on the lower stanchion, not as bad as some of the pictures Iíve seen but some started with the thin film.
    I sent a message off to my LBS and my mechanic and told him of my upcoming training weekends/camps in prep for Breck and he said to bring it in and it will get sent out for repair under warranty. Iíll be taking it in first thing tomorrow with hopefully a 2 week turn around.
  96. #496
    Oct 2011
    Yep I had this exact same problem, they really should have done a recall to fix them all once they realised the manufacturing issue. Apparently the carbon upper was not cleaned properly after being cut and ground to the correct diameter which led to large amounts of carbon dust and swarf which formed a carbon paste and contaminated the damping unit and damaged the seal/lower fork leg. My entire lower leg was worn so badly it had to be replaced and I assume they had to repair/replace the damping unit as well.
    Anyway it was fixed earlier this year under warranty and has had about 3-4 months of riding without any further issue.
  97. #497
    Oct 2011
    Lefty Ocho Volume Spacers
    Just one thing on tuning, I am pretty lightweight (62kg) but like to ride aggressively and have found the tuning window to be quite small on these to get the right balance between bottoming resistance and small bump sensitivity. The Ocho is still a massive improvement over the 2.0 but I think I can make it even better
    Anyone had a go at adding a volume spacer? Did you find this helped you reduce the air pressure to get the small bump sensitivity without having the fork feel too "divey" at the beginning of the stroke and still retaining/improving the bottoming resistance?
  98. #498
    Quote Originally Posted by daveinaus View Post
    Actually, does it have any volume spacers inside the Ocho?
  99. #499
    Oct 2011
    They sure do. Haven't looked at how easy they are to change but it appears as though its simply a matter of unscrewing the cap on the bottom of the fork and removing the assembly from the lower stanchion. Ill probably get my LBS to help me out with it first time around but would like to learn how to do it myself so i can have a play around with different settings on my local trails and get a feel for how it alters the damping characteristics. Like I said I think I have it very close to optimum setup but there's just this niggling idea in my head that I could improve the small bump sensitivity even more without compromising its ability to take bigger hits.
  100. #500
    Mine came without volume reducers (fsi world cup, carbon ocho)
    Both of my lefty 2.0 came with spacers installed.
  101. #501
    Oct 2011
    Perhaps I misunderstood but I took the question to mean, "can you fit volume spacers to the Ocho" which you certainly can. Whether or not they come with any fitted from factory I'm not sure. It would appear not though but I guess there's only one way to find out.
    Sent from my Pixel 2 using Tapatalk
  102. #502
    personally in all the Leftys I have tried and modified they all feel better without volume reducers...small bump sensitivity in my opinion is not as important as getting the fork to work through most of its travel as often as possible...both to reduce reset intervals and generally for smoother XC riding in mixed terrain
  103. #503
    I found that some movement from the lower stanchion of my Lefty Ocho, when you stand in front of the bike, hold the front wheel tight, apply the front brake and turn the handle bar left and right, I can feel thereís some movement, I am sure the headset and stem are tightened correctly. Is that something broken or loose inside? By the way, the needle bearings migrate pretty quickly, travel reduced down to about 50mm for around 1 km trail ride after a full bearing reset! Pretty frustrating right now!
  104. #504
    Jul 2019
    Ask me a question, does the Lefty suspension hollow if the lock is not installed, does the suspension stay in locked mode? What does activating its damping is the activation of the lock?
  105. #505
    Jan 2014
    Just sold my 2015 scalpel and purchased the 2019 scalpel 3.
    Iím keen to remove the spacer and have a steep seat tube and head tube angle, same as the CFR team riders do.
    Howís the knock block modification going for those who removed the spacer?
    Any photos of the knock block fitted?
  106. #506
    Ok, I just got the Ocho and the bike shop sold me a KP205...I noticed a gap when I installed it and I then referred to here. Seems like the bearing in that kit is the wrong one. Does anyone have the part number on the correct bearing? The only thing I could find was the K35029 for F-Si from Qwerty.
    Ok, after reading some more I read and saw Iím ďmissingĒ a lower headset cup and they donít make a 36deg bearing that goes directly into the frame. So I guess I know my answer unless there have been updates to what people have done.
  107. #507
    2019's have this issue, 2020's shouldn't. Send it in under warranty it can be fixed.
  108. #508
    There is no correct bearing for a carbon lefty on the scalpel to run no cup.
    I have a custom cut 36 degree bearing if anyone wants it. I sold my bike and put the cup back in.
    You will have a gap, there is no gap on the fsi or the scalpel with the cup because the bearing sits about 2mm inside the cup/frame. To do this on the scalpel you would need a very thin custom bearing made.
  109. #509
    Aug 2019
    I' am running with Cannondale SI Solid cranks (KP305). I measured a 178mm Q-factor. I'd like a narrower Q- Factor. What Q-Factor can I expect if i change my cranks for Hollowgram SI cranks (KP423)?
    Thanks in advance for your help.
  110. #510
    What did you get?
  111. #511
    Often times in threads we hear of lots of the negatives/issues people have and few comments on how spectacular a bike is... although there have been a number of guys lamenting how awesome this bike is! ... and I am going to add to that again.
    Last week I did the Breck Epic on my Scalpel and god damn, I was pleased! I am not a front runner, and coming from sea level Iím not a mid pack runner but I finished (not the point) and the Scalpel was awesome! Zippo mechanicals, no flats, no creaks, nothing. It handled all the nutso-downhills, drops, roots and rocks with poise and audacity (what movie is that from?!) and when I was not hiking with it, it really did climb like a mtn goat!
    Before the race I did start to notice the fork leak (mentioned way above) and had it sent it and new seals since then the Ocho has been great. I used a ShockWiz to help me tune and am super pleased.
    Being wary of the rocks/shale and one of the guys with his damaged Hollogram rim I have a set of Atomik Mtn Wheels laced to a Kappius rear hub ... but the rear has an annoying clang (worn pawl I think) every now and then so used the stock Hollogram rear with my upgraded I9 Hydra Hub and the Atomik Front. Tires were the Mezcal and Barzo Trail and gotta say am pleased with those tires. It rained cats and dogs on Day 1 and the Barzo even though a dry tire was fantastic!
    I put on the Magura Vyron Dropper and used it frequently, but the added weight was noticeable (same with the Atomik) and Absolute Black Oval Chainring, works great for me.
    Today, I had my first ride a week later after Breck, put the Hollogram on the front, and was lifting the front out of the corners like I was on a dirt bike! Awesomeness!!
    I wanted to put the OneUp EDC in the steering tube but after discussing it with OneUp they strongly discouraged against it. Iím not a huge fan of the various straps around the frame (wear/scratches...) and with the Dropper Post canít really use a seat bag so made my own for the bottle mounts, simple, clean and easy, one does tools and the other a tube. The bag holding the tools (seat tube) is a neoprene pencil case I got from the Dollar store. I sewed it in half and cut off the excess, works great! Biggest cost was the double sided velcro from Home Depot as I had aluminum kicking around the workshop.
    So, the Scalpel is Kick Ass!! I wonít be upgrading for the foreseeable future (the wife wonít let me anyway!!) Iím a happy camper!
    (No idea why when I post from my iPad the photoís rotate...)
  112. #512
    Congrats on the Epic! How much do you weigh? What pressure, rebound, and compression settings do you have the Ocho set to?
  113. #513
    I set the ShockWiz to analyze based on the Playful Option with the thought that I would run through the set up again in the Balanced Option which I think is more suited to my riding style (Iím not a masher, nor do I huck off of every rock or root) but still havenít gotten around to it and have a feeling how it would change if I did run it through as Balanced.
    My home trails are nothing like Breck, here we donít have the rocks or roots, predominantly all fairly smooth single track and actually have to build in rock features/gardens.
    Anyway...
    Weight 167lbs birthday suit.
    Suspension settings
    Rear 145psi
    9 clicks out from full fast
    Stock Racing Ralph 19psi
    Current Tire pressure - 21psi Mezcal Trail
    Front 136psi
    Rebound 15 clicks out from full fast
    Compression 4 clicks out from full +
    Stock Racing Ray 18psi
    Tire pressure - 20psi Barzo Trail
  114. #514
    Quote Originally Posted by scooterman View Post
    You mean the play of lower stanchion or bearing migration issue? Thanks
  115. #515
    Reputation: dreicha's Avatar
    Aug 2005
    And finally is it worth to upgrade from lefty 2.0 to ocho in terms of performance, not money? With L2.0 except for the bearing reset ritual, everything works flawlessly for years.
  116. #516
    from what I have been reading keep your lefty 2.0 ...
  117. #517
    new colours for Scalpel Si,,,, simply horrific!
  118. #518
    Wow, I weigh around the same and Iím around 120lbs right now for 25% sag...
  119. #519
    Iíve only got a few rides on my Ocho but my 2.0 was so unreliable. As far as performance, I removed a volume reducer in the 2.0 and as of right now, the Ocho might be a tad better but not huge as far as riding performance is concerned.
  120. #520
    I actually havenít checked the amount of sag, but do recall the Shockwiz saying that the rear shock is packing, or not full extending after hits and that it should be shimmed. Had I thought of it and not been as time crunched I would have sent it in when I sent in the Ocho to have the seals re-done.
  121. #521
    Iím referring to the Ocho.
  122. #522
    Jan 2018
    Quote Originally Posted by guidodg View Post
    Sponsored by.... Oreo Cookies?? Or a tuxedo rental shop??
  123. #523
    Iíll check front and rear and send you a message tomorrow.
  124. #524
    Quote Originally Posted by tgoods View Post
    designed by penguins?
  125. #525
    If the shock is packing then try speeding up the rebound
  126. #526
    Good advice! Iím riding tonight, will add a click!
    D
  127. #527
    I just got the Carbon Ocho and the bearings migrate super easy but also reset super easy...bunny hops will do it so hopefully jumps will too. Anyways, I was wondering how yours has been since you sent it out.
  128. #528
    Jul 2018
  129. #529
    Sep 2016
    Yeah
    Attached Thumbnails Attached Thumbnails 2019 Scalpel-SI with Lefty Ocho-04e8d356-bf41-4173-bc9c-ff8a21844780.jpg
  130. #530
    Iíll be happy to take that bearing off your hands!
  131. #531
    Jan 2014
    Very impressed with Scalpel(2019). It Rips, wish I had bought it earlier. Never thought it would be this much better than the 2015 team. But I prefer the lefty 2.0 on my Fsi. Only because after doing a jump the new lefty let a bunch of oil out!!.... which ended up on the brake rotor!
  132. #532
    the Ocho is not really made for the Scalpel...I see it more suited to the Fsi...
  133. #533
    Like the 2.0, there are a lot of production Ochos out there that are defective. After warranty, it should be good. Its unreal Cannondale releases so much defective equipment and you have to buy, break, warranty to have a good product. I just got my Carbon Ocho back and I only had it for 2 weeks. I will update on how it is on the Ocho Bearing Migration thread once I get a real ride on it.
  134. #534
    Reputation: Josh_W's Avatar
    Aug 2010
    ...I wanted to put the OneUp EDC in the steering tube but after discussing it with OneUp they strongly discouraged against it. Iím not a huge fan of the various straps around the frame (wear/scratches...) and with the Dropper Post canít really use a seat bag so made my own for the bottle mounts, simple, clean and easy, one does tools and the other a tube. The bag holding the tools (seat tube) is a neoprene pencil case I got from the Dollar store. I sewed it in half and cut off the excess, works great! Biggest cost was the double sided velcro from Home Depot as I had aluminum kicking around the workshop.
    Nice! Have any picks of the components, off the bike? I'm thinking about making something like this for the bottom-mounted down-tube cage bolts on my Rush, since I don't want or need a bottle-sized tool pod down there.
    Cannondale Fwhatever Optimo, Rush, & R600 Sport
  135. #535
    Nov 2018
    3 months ago my Hollowgram 23 rim snapped on a Scalpel Limited Edition 2019.
    I went to a local Cannondale dealer, payed a deposit and ordered a new one.
    A month later they tell me it is not possible to order it, Cannondale told them they are out of stock, and my order is dismissed.
    How would you respond to that ?
  136. #536
    That is shitty... Iím pretty sure the store can check stock right away or with a phone call, I know my guy can so waiting a month to find out is crap. But, not sure what you can do aside from showing/telling them you are not impressed, Iíd tell them I would be going elsewhere to find my replacement though.
  137. #537
    Delete
  138. #538
    sock puppet
    Reputation: osokolo's Avatar
    Why do you think that?
    Signature
  139. #539
    sock puppet
    Quote Originally Posted by dreicha View Post
    Yes it is so worth upgrading now that they addressed early issues with QC. Lighter, smoother and easier to get the right setup
    Signature
  140. #540
    sock puppet
    It is the case
    Signature
  141. #541
    Ocho definitely has bearing migration. Itís not as bad for me as the Lefty 2.0, though.
  142. #542
    Reputation: rumshcawheely's Avatar
    The migration is absolutely there, but if you run it so it uses its travel properly, itís pretty easy to voluntarily bottom it out every once in a while during your ride to be sure itís working in optimum rage. The ocho with bearing properly reset feels the best of all the modern gen lefties in my opinion.
    I personally feel that the original DLR2 SL with a soft top out spring was the best all time. Had to reset bearings once in a while, but the thing was super light, and with the boot and 88 needle bearings, no bushings, it just did itís job. Why would anyone in the world think the boot was a bad thing? ĒWait, that boot is keeping all the dust and dirt out of the telescope, letís get rid of it!!Ē, just makes no sense to me.
  143. #543
    Quote Originally Posted by rumshcawheely View Post
    ďRunning it to use its travel properlyĒ is kind of a simplified description of a very technical and multifaceted process of tuning the Ocho. Ive had no less than 25 Leftys over the years and have the technical skills and knowledge to manipulate about every aspect of its suspension attributes.
    I wish I had the same opinion and experience. Unfortunately even with all of the high level tuning Iíve done, I cannot get the optimal balance that youíve achieved. It seems that the Leftys have always been difficult for lighter riders to tune to get that balance. The Ocho is an improvement over previous iterations but it is certainly still not ideal.
  144. #544
    It took me warrantying it twice within weeks of purchasing mine to get that balance. They even admitted that no 2 are alike and they changed how they are tuning and manufacturing them just a few weeks ago. This is at least the 3rd iteration of tuning from when they were first conceived. The fork was (or is) a work in progress for sure I feel I did a lot of the testing for them and I paid for it! I tried so many different air pressures, rebound tuning, making sure I mimicked the same ride all because I could not get it to feel right. It is great now, but the amount of trial and error plus bitching to get it right was crazy. Hopefully my unpaid R&D benefits everyone else...
  145. #545
    The failure looks consistent with the rim not being able to bend enough which indicates a manufacturing problem. My rims are full of rock strike scratches but have not failed. Your rim doesn't have any strike indicating marks
  146. #546
    Quote Originally Posted by osokolo View Post
    first of all on some frame sizes the Ocho on the Scalpel hits the frame when turned to the extreme left... a cracked frame waiting to happen
    secondly the skinny steerer tube sticking out of the top of the frame with that horrible stem...just looks wrong
    thirdly too much flex compared to the 2.0 which complements the Scalpel perfectly
    four... bearing migration not really resolved
    I think it may be worth waiting for the new Scalpel which may be designed around the Ocho...bit I wouldnít hold my breath
  147. #547
    sock puppet
    Everyone is entitled to their opinion. Even if it is wrong.
    OCHO is way better than 2.0. Smoother and lighter. Easier to adjust. No bearing issues for me as I dialed it so that it uses full travel every time I ride it. Didnít hear anyone cracked their frame the way you describe it. Doubt it will happen. At 200 pounds I havenít noticed it not being as stiff as 2.0 which I ride for a full season before Ocho.
    But glad you are liking 2.0. Thatís why we have options
    Signature
  148. #548
    I donít notice any flex and I am aggressive. The fork will not hit the frame if you purchase the appropriate headset specially made for the Scalpel and Ocho.
    The Stem and steerer looks incredible on my Scalpel.
    Bearing issues are there on many Ochos but can be rectified and hopefully on all the ones being manufactured now are rectified.
  149. #549
    Is there a pathway you would suggest to rectify the issue on an early Ocho?
  150. #550
    Quote Originally Posted by ToastR View Post
    Warranty is the only way. I had to do it twice within 2 weeks. Supposedly my bearings were tightened to 4.5nm to make it work correctly.
  151. #551
    Agreed on the set up process, it is very involved. And I do, in this case have a huge weight advantage!! 😬, but Iíd certainly trade the suspension feel Iím getting for a better feel in sustained climbing!!! Guess I canít expect a bike to offset that... but a hard tail at 19lbs under me back at fighting weight will be a hoot. Looking forward to it.
    I do still stand firm that the booted lefty 110SL (DLR2) before solo air was the BOMB!!
  1. The Ocho 8 Hour Race 4/14/2012 (Morristown, TN)
    By DHolmes1 in forum Endurance XC Racing
    Last Post: 02-16-2012, 06:34 PM
  2. Gnome-Fest {([OCHO]})! Sept. 9-11 @ Levis
    By ~gomez~ in forum Minnesota, Wisconsin
    Last Post: 11-17-2011, 07:09 PM
  3. 2011 Ocho 8 Hour Race April 17th
    By DHolmes1 in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 04-15-2011, 03:21 AM
  4. 2011 Ocho 8 Hour Race April 17th
    By DHolmes1 in forum North & South Carolina
    Last Post: 04-11-2011, 06:35 AM
  5. 2011 Ocho 8 Hour Race April 17th
    Last Post: 04-11-2011, 06:33 AM
Members who have read this thread: 187
