Results 1 to 2 of 2
    May 2005
    2013 26" 130mm to 29"?
    I have a 2013 130mm 26" carbon XLR and was wondering if anyone knows if it can be reduced to 100-110 for a 29er. I've read that the bearings are now responsible for limiting travel so I'm confused as to whether I can limit a 26" externally on the cartridge like we used to with the older generation. Any help would be appreciated.
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    Quote Originally Posted by Sean Allan View Post
    From what I know the cartridges are still the same, so spacers on top and the appropriate air volume reducers should do the trick.....But, in order to do a proper bearing reset you would have to remove those spacer clips, release all air and fully compress the fork.
    Mendon should be able to chime in here.
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
