    Feb 2013
    2012 Scalpel Di2 compatible?
    Hey All- I'm really new to the Cannondale world so bear with me. I just bought a 2012 Scalpel Carbon 2 and I'm in the midst of upgrading some components to lighten it up amd to make it a bit more aesthetically pleasing. Can I put Di2 on this frame? Not sure im going that way but want to know if I have the option.The bike heads out shortly for a custom BOB paint scheme with new enve bar and wheels-should look fairly sick when its complete- Thanks guys
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    with a Dremel you can do everything
    I don't see why not. Shimano has battery mounts that attaches to your frames water bottle mount. Of course it's not going to be as clean as a modern frame that's built for DI2 with the battery hidden in the frame.
    You can certainly externally wire the frame with the external battery and external junction box. Newer scalpel frames have a hole in the seat tube for a dropper post. I'm running 1x11 so I'm able to run the wire externally to this area and plug into internal battery, then take junction wire from junction B out that hole and externally to the RD.
  1. Replies: 14
    Last Post: 06-11-2013, 03:43 PM
  2. 2012 Fox Float 100mm 650b compatible?
    By PannikAttk in forum 27.5
    Last Post: 04-01-2013, 07:13 PM
  3. 2012 Scalpel 1 or 2
    By torque29er in forum Cannondale
    Last Post: 03-14-2012, 03:12 AM
  4. 2012 Remedy 9.9 compatible with Angleset?
    By OneEyedHito in forum Trek
    Last Post: 03-03-2012, 05:02 PM
  5. 2012 Endorphin 650B compatible?
    By bubba13 in forum Knolly
    Last Post: 01-18-2012, 12:40 PM
