2012 Flash 3 cracking sound in headtube- Mtbr.com
Results 1 to 7 of 7
    Dec 2005
    I have recently purchased a flash 3 carbon, I changed the stem to a less angled -5 and am constantly hearing a cracking sound from the steering area. The bike made no sound from new with the origanial stem, but as soon as I changed it I can't seem to get rid of the sound.
    I have reassembled it a number of times torquing it to the correct setting and applied heaps of grease everywhere. It starts the ride out quiet then half way through it starts again.
    Any help or someone that has had the problem would be great
    Thanks.
    May 2010
    Have you pulled the bearings out of the frame yet? Cannondale almost never puts grease between the bearings and frame and it ends up creaking everytime.
    Dec 2005
    No I haven't pushed out the bearings I will try that.
    Reputation: chick0's Avatar
    You could also check that the bar is even and flush within the stem face plate. I had similar problem when i switch stem once, and although i used a torque wrench to fit everything, it turned out the bars were not seated correctly...
    Reputation: broomhandle's Avatar
    its prob a rubbing no grease issue. no way cracks. a crack you would probably never hear, it would just be there.
    and yes, it could be a bar/stem bolt not tight issue as well.
    Dec 2005
    Thanks cityloopcycles the bearings were the problem, pushed them out, greased and pressed back in, all good.
    May 2010
    Quote Originally Posted by alienonabike View Post
    you're welcome! enjoy your quiet rides
  1. Cracking sound when I hit a bump
    By Yuri Natenpuhl in forum Specialized
    Last Post: 09-12-2011, 12:58 PM
  2. Blur XC Carbon Loud Cracking Sound!!
    By back40 in forum Santa Cruz
    Last Post: 05-25-2010, 08:03 PM
  3. 575 cracking sound!!
    By markyboy in forum Yeti
    Last Post: 03-14-2010, 05:13 PM
  4. <5.5> cracking noise from the headtube area
    By StabbedDawg in forum Intense
    Last Post: 12-12-2006, 06:34 PM
  5. Prophet 2000 - Cracking sound.
    By Arbor in forum Cannondale
    Last Post: 08-29-2006, 11:28 AM
